Go Back   Avid Pro Audio Community > Pro Mixing > Pro Tools | Control
Old 06-10-2019, 01:45 PM
Cheesehead Cheesehead is offline
Default Send windows disappear when clicking on edit window
Since the latest version of PT Control I have this issue.
It doesn't necessarily happen all the time.
It used to be that a send window would stay open until I closed it myself, but now sometimes if I click in the Edit window the send will close itself.
Particularly annoying when using bus interrogation etc, you have to go back and find the track and the send that you had open before you showed only the tracks with that send.
Is there a way to switch off this behaviour?
Mac Pro 6,1 12 core, OSX 10.12.5, HD-Native TB, Trinnov MC, 888 IO, 192 IO, Sync HD, AJA IO XT, MC Mix, PT Control, Eucon 19.5, PT 2019.5
Old 06-10-2019, 02:09 PM
BScout BScout is offline
Default Re: Send windows disappear when clicking on edit window
uncheck "Close Windows on Workstation When Exiting" in EuControl
It does seem that should be tied to the option above ("Open Windows on Workstation When Editing" choice) vs being global but for now it is all or nothing.
Pro Tools Ult 2019.6, HDX 3, MTRX/SPQ, HD OmniMac Pro 5,1 - 3.06 GHz 12 core - macOS 10.13.6RAM 64GB, SSD 4 x 2TB, GPU GTX 980 4GB
Old 06-11-2019, 10:56 AM
EddieJones's Avatar
Can you screen grab your EuControl Prefs..its staying open here for us (If you have the Sends Windows selected to Open in the Drop down Pref)
Old 06-11-2019, 11:39 AM
And if you have it set to "Plugins Only", do you see the closing behaviour on Send windows?
For instance, I manually open sends when I want them, but changing to another track will kill the send window.
Old 06-11-2019, 02:05 PM
Thanks BScout, Eddie.
unchecking "Close Windows on Workstation When Exiting" seems to have solved it.
Been working fine all day today.
I have the drop-down set to plugins only.
There are quite a few options in this new release to get your head around & not massively clear which ones cause the surface to follow PT or PT to follow the surface.
I seem to have hit a sweet spot now though.
New Bug 2018? Edit window jump to vcas when clicking on plugins JuelzB Pro Tools 2018 0 03-04-2018 01:35 AM
Bug? - Clicking in edit window selects everything cheeseandpepper 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 9 07-17-2012 05:11 AM
BUG: All Clips in Edit Window Disappear! conleec Pro Tools 10 3 01-17-2012 10:13 AM
Playback interrupts when clicking on edit window. pcmusicpro 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 12-04-2009 10:15 AM
Clicking in Edit window does not move playback marker...help! Lofty11 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 02-28-2009 09:01 PM
