Old 12-02-2003, 09:37 AM
apetrocelli apetrocelli is offline
Default Digi 001 standalone drivers?
hi, I have a digi 001 in my mac. I want to use it in a new pc, with Cubase for XP. I know the audio part is routed by the ASIO drivers. Now, how do I make the pc to recognize the 001's midi ports, without having Pro Tools installed?
Thanks in Advance. Andrés
Old 12-02-2003, 09:45 AM
msog msog is offline
Default Re: Digi 001 standalone drivers?
I'm pretty sure that you have to have PT installed to do anything with the 001.
Thanks,
Jim (I used to be alot younger)
Old 12-02-2003, 11:30 AM
where02190 where02190 is offline
I too believe yuo cannot do anything with the hardware without having Protools installed.
Old 12-02-2003, 01:17 PM
GapeOne GapeOne is offline
Why not install protools!???
www.myspace.com/soulskool
Old 12-03-2003, 05:59 AM
is not that I don't want to install Pro Tools. The issue is that I have my Digi on the mac, with Pro Tools mac version. I don't have the pc version. Andrés
Old 12-03-2003, 01:00 PM
The Weed's Avatar
The Weed The Weed is offline
Pro Tools normally ships with both the Mac and PC versions in the box. You should have both, but the hardware has to be installed to the computer using PT or it won't install and it won't work. They use the hardware as a very big - and expensive - dongle.
Cheers,
non-union national read at a reasonable rate
Demos: brucehayward dot com
Source-Connect: brucehayward
Old 12-03-2003, 02:52 PM
thanks. I think the installer is just for mac, since I am using a 6.x version which I think it didn't even appear for Windows (I guess it was the 6.0 version, with subsequents upgrades up to the latest). I'm pretty sure that at least the updates are not pc compatible, and the original isn't either.
Old 12-03-2003, 03:24 PM
The Weed's Avatar
You may be able to get a cross-grade to PC for little or no money. Check with customer service.
Cheers,
mBox 2 Standalone Drivers for XP pro larryloo Pro Tools TDM Systems (Win) 0 03-01-2012 08:50 PM
Mbox 2 standalone drivers Venta 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 12-19-2010 07:20 AM
Standalone CoreAudio drivers 8.04 ??? DuetLooser 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 07-11-2010 06:38 AM
Standalone ASIO drivers for Win7 x64 kenzo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 12-21-2009 08:57 AM
Win 7 & mbox2 standalone drivers SteveGam 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 11-26-2009 07:26 PM
