Old 11-24-2009, 02:31 PM
SteveGam SteveGam is offline
Default Win 7 & mbox2 standalone drivers
Got a new laptop with Win 7. Need to get my mbox2 running on it for SMAART use, protools will not be installed on this machine. Installed the 7.4 standalone drivers but no go. Even tried the "run as admin" trick but no sound.
The Mbox seems to be running OK, all the lights and switches work, +48 works, sound to headphones works... but nothing shows up in the win 7 sound control panel or in SMAART's audio I/O device selector.
any ideas?
thanks,
Steve
Working for the preservation of quality live sound.... One show at a time!
Work
Twin S6L's
PM-10
Profile, D-Show
3 Midas Heritage's and 5 M32's
Several other analog and digital consoles
d&b J Systems
L'Acoustics V-Dosc systems
Home: Compaq Z800
Dual XEON hexes
48G Ram
Windows 10
Midas M32 and XL48
Genelec 8050's with Genny sub
Genelec 8030's
JBL L96 & LSR32
Old 11-24-2009, 02:43 PM
sw rec sw rec is offline
Default Re: Win 7 & mbox2 standalone drivers
Just like there wasn't (isn't) a "standalone" Vista driver, there also isn't a "standalone" W7 driver. At least not yet.
That's actually a Pro Tools interface, and wasn't intended to be a "soundcard" per se.
Old 11-24-2009, 03:14 PM
Not using it as a soundcard, Just need working asio drivers to use the preamp as I have been for 3 years with XP.
Work
Twin S6L's
PM-10
Profile, D-Show
d&b J Systems
Home: Compaq Z800
Dual XEON hexes
48G Ram
Windows 10
Midas M32 and XL48
Genelec 8030's
JBL L96 & LSR32
Old 11-24-2009, 03:24 PM
mykhal c's Avatar
mykhal c mykhal c is offline
any ideas?
thanks,
Steve
2 choices...
1) install PTLE and then 'only' remove the PTLE and leave the drivers installed
2) install the 7.4 drivers again...use 'run as admin' and 'Vista SP2' mode
*** use this in step 1 too....use 'run as admin' and 'Vista SP2' mode
bassist...deep pocketz anyone???!!!
The Basschakra Lucid Soul Trip
i7 Builds - Specs and Results
HDNative | Omni | i7-3930K OC'd 4.0GHZ |
ASUS X79 Sabertooth | 32GB GSkill DDR3 2133 ram | mo' stuff
Old 11-24-2009, 06:04 PM
uz3r uz3r is offline
Are you using Win 7 32 or 64bit?
I have not been able to get my USB Mbox2/PTLE7.4 working on Win7 64, using run as admin or vista SP2 compatability mode didnt help. Digi dont support Win 7 yet so good luck, you'll need it.
Old 11-26-2009, 07:26 PM
Thanks for the tip Mykhal C. Installed PT8, Mbox2 asio now works like a charm.. Even works as a soundcard if thats what your after. My SMAART system is up and running in win7. Only a couple apps left to load and all will be great!!
Steve
BTW, win7 rocks with speed. No blue screens, network stuff is a bit strange due to increased security.
Work
Twin S6L's
PM-10
Profile, D-Show
d&b J Systems
Home: Compaq Z800
Dual XEON hexes
48G Ram
Windows 10
Midas M32 and XL48
Genelec 8030's
JBL L96 & LSR32
mBox 2 Standalone Drivers for XP pro larryloo Pro Tools TDM Systems (Win) 0 03-01-2012 08:50 PM
Mbox 2 standalone drivers Venta 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 12-19-2010 07:20 AM
Standalone CoreAudio drivers 8.04 ??? DuetLooser 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 07-11-2010 06:38 AM
Standalone Mbox2 mini Vista drivers Martinus 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 01-12-2009 11:28 AM
Digi 001 standalone drivers? apetrocelli 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 12-03-2003 03:24 PM
