Old 05-16-2005, 07:22 AM
stereo type stereo type is offline
Default 6.9 Vs 6.7 for CPU usage
I have 2 boot drives. At some point, there will be different things installed on each as I plan to have one with soft synths and one that has a "clean" uncluttered PT volume for use when clients are here.
But for right now, Each has an identical version of Win XP. Each has nothing other than PT added after formatting and installing WIN XP on each drive. The only difference is one has PT LE 6.7 (cs8); the other has been upgraded to 6.9. Audio is on a third (SATA) dedicated audio drive.
Buffer settings are the same; prefs are the same in both PTs. But a large session with heavy edits, lots of plugins and full 32 tracks will choke on 6.9. The very same session, with no changes made will play just fine. And just as a test, the session can even have a few more plugins added on 6.7.
So what's the difference between 6.7 and 6.9?
P4/WIN XP/3.0Ghz/1GB RAM
OO2r
Old 05-16-2005, 07:24 PM
Default Re: 6.9 Vs 6.7 for CPU usage
Interesting...On my system, I noticed that 6.7 was more cpu-hungry than 6.4, but saw no change from 6.7 to 6.9. I still run 32+4to6 stereo aux tracks with little trouble.
What would normal disk usage considered to be in the usage window? Digitopian 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 09-08-2009 09:50 PM
Help understanding CPU Usage, RAM, Disk Usage... Bezo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 12 02-03-2006 07:41 PM
HTDM not showing CPU usage in the system usage Brandonx1 Pro Tools TDM Systems (Win) 3 12-19-2004 09:45 AM
CPU usage Room24Prod 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 11-16-2004 06:20 PM
DSP Usage? Smithtrax Pro Tools TDM Systems (Mac) 1 10-15-2003 02:13 PM
