Glitches in audio after recording
This is a new issue that has started after upgrading to PT 7.4/7.4cs1. During recording, audio sounds fine but upon playback, gltches sometimes appear in the audio (zooming in on the waveform also shows the glitches and spikes). It sounds very similar to a clocking issue, except that here, I have only one 192IO and it is clocked internally. The ticks vary in amplitude but at times seem evenly spaced with no relation to the session tempo and if I immediately re-record the section, I get a clean recording. The problem is sporadic and unpredicatable but once it starts it tends to happen more frequently. No other sync or digital devices are being used. I've run DigiTest on both my core and accel card (both passed). I've also checked and re-checked cabling to make sure my 192IO connection to my core card is secure.
I realize that this may be a hardware issue but thought I'd share my experience here to see if anyone has seen anything like this. Thanks all, Ben WinXP Pro SP2 HD2 Accel PT 7.4cs1 192 IO (w/ extra AD card)
Windows 10 Pro x64 Avid HDX running PT Ultimate 2020.x ASUS WS x299 SAGE 10g Intel i9-10980xe 64 GB DDR4 3200 RAM Matrox C420 Avid Artist Mix |
Re: Glitches in audio after recording
Did some more investigating with this...
On one of the sessions I experienced this in, I noticed the glitches appear very close to the bar lines on the grid (but not exactly on, there is a bit of drift). I also noticed that there are very similar glitches (at the same times) on an alternate take on the smae tracks (mutitracked drums, in this case). I don't see how this could happen unless it was witin the PT hardware/software environment. Digi, any thing else I can do to test my hardware? Ben
Sorry for resurrecting this about a year later, and sorry for the long post coming....
I just developed the same problem. I've been using an HD1 and recently changed a motherboard to accommodate another Accel card on it's way. I haven't installed the card yet, so it's still HD1. I noticed this because a regular client I've had for years came in for a regular session, first one on this new mobo. He's a classical guitarist. Comes in, plays for about an hour or 2 non-stop while i'm just recording and taking notes. Always rolling and not stopping record unless he needs a break. Everything went fine. He left and was to come back the next day after I compiled a CD of takes and versions. While I was prepping the CD, I noticed after about 30 min of recording, glitches appeared in the recording, viewable in the waveforms, that were DEFINITELY not audible while tracking and monitoring the recording. I've done several tests, driver updates, drive swaps, HD card slot swaps, bios updates, overclock, underclock, etc, and can't track it down. The glitches appear after some time, between 20min to an hour of constant recording, and are then consistently appearing a little more than every second. Everytime they are not audible while tracking, but definitely afterwards in playback, and viewable in the waveforms. The tests I've been doing have been a signal generator on an Aux track, bussed out to an audio track bus input and recording various numbers of tracks. The motherboard is an Asus P5QL-E, Intel Q6600, 4GB DDR2 1066, P43 chipset, ICH10R, HD1 Accel PCIe, 192io. Here's the kicker, I ran the test in Nuendo 3 that's installed on this machine also, using the Digi ASIO driver and it was perfectly glitch free..... The previous system did not have this problem since the client I noticed this with has been coming in for years, several sessions a month, and this has not happened. I belive it's something in how the HD card is interacting with the SATA bus in how the data is getting written to the drive. Anyhow, any ideas anyone? I have a new mobo on order - an Asus P5Q that has the P45 chipset and is supposedly a bit more robust. We'll see how that goes.... Thanks in advance for any insight. Peace, Ryan |
Please post a Sandra report, per the info in the General Troubleshooting thread, so we can see exactly what we're working with. You may also want to look through that thread to see if any of the optimizations/troubleshooting may help you.
Here goes the Sandra Report:
SiSoftware Sandra System Host Name : STUDIO User : Ryan Hafer Workgroup : SECRETNINJA Processor Model : Intel(R) Core(TM)2 Quad CPU Q6600 @ 2.40GHz Speed : 2.40GHz Cores per Processor : 4 Unit(s) Threads per Core : 1 Unit(s) Type : Quad-Core Internal Data Cache : 4x 32kB, Synchronous, Write-Thru, 8-way, 64 byte line size L2 On-board Cache : 2x 4MB, ECC, Synchronous, ATC, 16-way, 64 byte line size, 2 threads sharing System System : System manufacturer P5QL-E Mainboard : ASUSTeK Computer INC. P5QL-E Bus(es) : ISA PCI PCIe IMB USB i2c/SMBus Multi-Processor (MP) Support : No Multi-Processor Advanced PIC (APIC) : Yes System BIOS : American Megatrends Inc. 0905 Total Memory : 3.25GB DIMM DDR3 Chipset Model : ASUS P45/P43/G45/G43 DRAM Controller Front Side Bus Speed : 4x 267MHz (1.07GHz) Total Memory : 4GB DIMM DDR3 Memory Bus Speed : 2x 534MHz (1.07GHz) Video System Adapter : NVIDIA GeForce 8600 GT (256MB DDR3, 550MHz/1.28GHz/2x720MHz, PCIe 1.00 x16, PS3.0, VS3.0, 2 Heads) Adapter : NVIDIA GeForce 8600 GT (256MB DDR3, 550MHz/1.28GHz/2x720MHz, PCIe 1.00 x16, PS3.0, VS3.0) Graphics Processor Adapter : GeForce 8600 GT (1.01, 256MB, 1.46GHz) Storage Devices ST3500320AS 500GB (SATA300, 3.5", NCQ) : 466GB (C:) (D:) ST31000340AS 1TB (SATA300, 3.5", NCQ) : 932GB (E:) (F:) PLEXTOR DVDR PX-760A (ATA66, DVD+-RW, CD-RW, 2MB Cache) : N/A (M:) Logical Storage Devices Windoze (C:) : 50GB (NTFS) @ ST3500320AS 500GB (SATA300, 3.5", NCQ) Storage (D:) : 416GB (NTFS) @ ST3500320AS 500GB (SATA300, 3.5", NCQ) Audio 1a (E:) : 466GB (NTFS) @ ST31000340AS 1TB (SATA300, 3.5", NCQ) Audio 1b (F:) : 466GB (NTFS) @ ST31000340AS 1TB (SATA300, 3.5", NCQ) CD-ROM/DVD (M:) : N/A @ PLEXTOR DVDR PX-760A (ATA66, DVD+-RW, CD-RW, 2MB Cache) 3.5" 1.44MB (A:) : N/A Peripherals LPC Hub Controller 1 : ASUS LPC Interface Controller Disk Controller : ASUS 6 port SATA AHCI Controller Disk Controller : ASUS JMB36X PCIE-to-SATAII/IDE RAID Controller USB Controller 1 : ASUS USB UHCI Controller #4 USB Controller 2 : ASUS USB UHCI Controller #5 USB Controller 3 : ASUS USB UHCI Controller #6 USB Controller 4 : ASUS USB EHCI Controller #2 USB Controller 5 : ASUS USB UHCI Controller #1 USB Controller 6 : ASUS USB UHCI Controller #2 USB Controller 7 : ASUS USB UHCI Controller #3 USB Controller 8 : ASUS USB EHCI Controller #1 System SMBus Controller 1 : Intel 801xx/63xx SMBus Printers and Faxes Printer : HP PSC 1600 series (USB, Colour) Network Services Network Adapter : Atheros AR8121/AR8113/AR8114 PCI-E Ethernet Controller - Packet Scheduler Miniport (Ethernet, 100Mbps) Power Management Mains (AC) Line Status : On-Line Operating System(s) Windows System : Microsoft Windows XP Professional 5.01.2600 (Service Pack 3) Platform Compliance : x86 ----------------- SiSoftware Sandra System Manufacturer : System manufacturer Model : P5QL-E Family : To Be Filled By O.E.M. Version : System Version Serial Number : System Serial Number ID : 1E001B20-8901008C-2300036C-0E102854 SKU Number : To Be Filled By O.E.M. System Chassis Manufacturer : Chassis Manufacture Type : Desktop Can be locked : No Version : Chassis Version Power Cord(s) : 1 Serial Number : Chassis Serial Number Asset Tag : Asset-1234567890 Boot-up State : Safe Power State : Safe Thermal State : Safe Security State : External Interface Locked-out Mainboard Manufacturer : ASUSTeK Computer INC. Multi-Processor (MP) Support : No MPS Version : 1.40 Model : P5QL-E Type : Mainboard Version : Rev 2.xx Serial Number : MS1C89B23U02717 Asset Tag : To Be Filled By O.E.M. Location in Chassis : To Be Filled By O.E.M. System BIOS : 64-0905-000001-00101111-120108-Eaglelake System Mainboard Properties Removable : No Replaceable : Yes Hot Swap : No On-board Devices Onboard Ethernet : Ethernet Adapter (Enabled) System Memory Controller Location : Mainboard Error Correction Capability : None Number of Memory Slots : 4 Maximum Installable Memory : 16GB BANK0 - DIMM0 : Manufacturer00 ModulePartNumber00 SerNum00 AssetTagNum0 DIMM Synchronous DDR2 2GB/64 @ 1.07GHz BANK1 - DIMM1 : Empty BANK2 - DIMM2 : Manufacturer02 ModulePartNumber02 SerNum02 AssetTagNum2 DIMM Synchronous DDR2 2GB/64 @ 1.07GHz BANK3 - DIMM3 : Empty Chipset Model : ASUS P45/P43/G45/G43 DRAM Controller Revision : A4 Bus : Intel AGTL+ Independent FSB Channels : 1 Front Side Bus Speed : 4x 267MHz (1.07GHz) Width : 64-bit Crossfire Technology : Yes I/O Queue Depth : 12 request(s) Maximum Bus Bandwidth : 8.34GB/s Features TXT - Trust Execution Technology : Yes ME - Management Engine : Yes AMT - Active Management Technology : Yes VT-d - Virtualisation Technology : Yes EF - EastFork Technology : Yes AP - Agent Presence : Yes CB - Circuit Breaker : Yes Auto Fan Speed Control : Yes Chipset 1 Hub Interface Type : DMI (Direct Media Interface) Version : 1.00 Number of Ports : 4 In/Out Width : 4-bit / 4-bit Multiplier : 3/1x Speed : 1x 100MHz (100MHz) Logical/Chipset Memory Banks Bank 0 : 1GB DIMM DDR3 2-5-5-18 3-23-10-7 2T Bank 1 : 1GB DIMM DDR3 2-5-5-18 3-23-10-7 2T Bank 4 : 1GB DIMM DDR3 2-5-5-18 3-23-10-7 2T Bank 5 : 1GB DIMM DDR3 2-5-5-18 3-23-10-7 2T Maximum Installable Memory : 8GB Supported Memory Types : DIMM DDR2 DDR3 Channels : 2 Memory Bus Speed : 2x 534MHz (1.07GHz) Multiplier : 8/4x Width : 64-bit Memory Controller in Processor : No FMA - Fast Memory Access Support : Yes Refresh Rate : 7.80µs Power Save Mode : No Fixed Hole Present : No Maximum Memory Bus Bandwidth : 16.69GB/s APIC 1 Version : 2.00 Multiplier : 1/2x Maximum Interrupts : 24 IRQ Handler Engaged : Yes Enhanced Support : Yes Memory Module Manufacturer : Corsair Model : CM2X2048-8500C5D Extended Information : mVN Type : 2GB DIMM DDR2 Technology : 16x(128Mx8) Speed : PC2-6400U DDR2-800 Standard Timings : 5.0-5-5-18 3-23-6-3 Version : 1.02 Memory DC Line : 1.80V Set Timing @ 400MHz : 5.0-5-5-18 3-23-6-3 Set Timing @ 270MHz : 4.0-3-3-12 2-15-4-2 Enhanced Performance Profiles : Yes Profile @ 533MHz: Optimal : 5-5-5-15 X-22-32-X 2T 2.1V Memory Module Manufacturer : Corsair Model : CM2X2048-8500C5D Extended Information : mVN Type : 2GB DIMM DDR2 Technology : 16x(128Mx8) Speed : PC2-6400U DDR2-800 Standard Timings : 5.0-5-5-18 3-23-6-3 Version : 1.02 Memory DC Line : 1.80V Set Timing @ 400MHz : 5.0-5-5-18 3-23-6-3 Set Timing @ 270MHz : 4.0-3-3-12 2-15-4-2 Enhanced Performance Profiles : Yes Profile @ 533MHz: Optimal : 5-5-5-15 X-22-32-X 2T 2.1V Environment Monitor 1 Model : Winbond W83627DHG-A ISA Version : 12.01 Mainboard Specific Support : No Environment Monitor 2 Model : Intel Core CPU [P1, C4, M0] Version : 15.11 Mainboard Specific Support : No Temperature Sensor(s) Board Temperature : 28.00°C CPU Temperature : 36.50°C td Auxiliary Temperature : 25.50°C Cooling Device(s) Auto Fan Speed Control : Yes System Fan : 1223rpm CPU Fan : 1962rpm Auxliary Fan : 5315rpm Voltage Sensor(s) CPU DC Line : 1.27V Aux DC Line : 3.38V +3.3V DC Line : 3.37V +5V DC Line : 4.16V +12V DC Line : 11.42V Standby DC Line : 3.41V Battery DC Line : 0.10V System Bus(es) on Hub 1 Version : 2.30 System Bus 0 : PCI System Bus 1 : PCIe 2.00 x16 2.5Gbps System Bus 2 : PCIe 1.00 x1 2.5Gbps System Bus 3 : PCIe 1.00 x1 2.5Gbps System Bus 4 : PCIe 1.00 x1 2.5Gbps LPC Hub Controller 1 Model : ASUS LPC Interface Controller Revision : A1 ACPI Power Management Enabled : Yes Advanced TCO Mode Support : Yes Advanced TCO Mode Enabled : No High Precision Timer Enabled : Yes Number of Precision Timers : 4 System Timer : 14.32MHz Delayed Transaction Enabled : Yes Disk Controller Model : ASUS 6 port SATA AHCI Controller Interface : SATA Revision : A1 Specification : 1.10 Maximum SATA Mode : G2 / SATA300 Channels : 6 In Use Channels : 2 Port : G2 / SATA300 Port : G2 / SATA300 Disk Controller Model : ASUS JMB36X PCIE-to-SATAII/IDE RAID Controller Interface : ATA Revision : A4 Channels : 4 USB Controller 1 Model : ASUS USB UHCI Controller #4 Revision : A1 Version : 1.10 Interface : UHCI Channels : 2 Speed : 48MHz Supported Speed(s) : Low (1.5Mbps) Full (12Mbps) Legacy Emulation Enabled : No USB Controller 2 Model : ASUS USB UHCI Controller #5 Revision : A1 Version : 1.10 Interface : UHCI Channels : 2 Speed : 48MHz Supported Speed(s) : Low (1.5Mbps) Full (12Mbps) Legacy Emulation Enabled : No USB Controller 3 Model : ASUS USB UHCI Controller #6 Revision : A1 Version : 1.10 Interface : UHCI Channels : 2 Speed : 48MHz Supported Speed(s) : Low (1.5Mbps) Full (12Mbps) Legacy Emulation Enabled : No USB Controller 4 Model : ASUS USB EHCI Controller #2 Revision : A1 Version : 2.00 Specification : 1.00 Interface : EHCI Channels : 6 Companion Controllers : 3 Supported Speed(s) : Low (1.5Mbps) Full (12Mbps) High (480Mbps) Addressing Support : 64-bit Legacy Emulation Enabled : No USB Controller 5 Model : ASUS USB UHCI Controller #1 Revision : A1 Version : 1.10 Interface : UHCI Channels : 2 Speed : 48MHz Supported Speed(s) : Low (1.5Mbps) Full (12Mbps) Legacy Emulation Enabled : No USB Controller 6 Model : ASUS USB UHCI Controller #2 Revision : A1 Version : 1.10 Interface : UHCI Channels : 2 Speed : 48MHz Supported Speed(s) : Low (1.5Mbps) Full (12Mbps) Legacy Emulation Enabled : No USB Controller 7 Model : ASUS USB UHCI Controller #3 Revision : A1 Version : 1.10 Interface : UHCI Channels : 2 Speed : 48MHz Supported Speed(s) : Low (1.5Mbps) Full (12Mbps) Legacy Emulation Enabled : No USB Controller 8 Model : ASUS USB EHCI Controller #1 Revision : A1 Version : 2.00 Specification : 1.00 Interface : EHCI Channels : 6 Companion Controllers : 3 Supported Speed(s) : Low (1.5Mbps) Full (12Mbps) High (480Mbps) Addressing Support : 64-bit Legacy Emulation Enabled : No System SMBus Controller 1 Model : Intel 801xx/63xx SMBus Specification : 2.00 Advanced TCO Mode Enabled : Yes Slave Device Enabled : Yes PEC Support : Yes Speed : 100kHz Expansion Slot(s) PCIEX16 (1h) : PCIe 32-bit +3.3V Shared PME Half-Length Used PCIEX1_1 (8h) : PCIe 64-bit +3.3V Shared PME Half-Length Used PCIEX1_2 (9h) : PCIe 32-bit +3.3V Shared PME Half-Length Available PCI_1 (2h) : PCI 32-bit +3.3V Shared PME Half-Length Available PCI_2 (3h) : PCI 32-bit +3.3V Shared PME Half-Length Available PCI_3 (4h) : PCI 32-bit +3.3V Shared PME Half-Length Available Port Connector(s) PS/2 Keyboard - PS/2 Keyboard : Keyboard / PS/2 PS/2 Mouse - PS/2 Mouse : Mouse / PS/2 USB12 - USB12 : USB / USB USB34 - USB34 : USB / USB USB56 - USB56 : USB / USB GbE LAN - GbE LAN : Network / RJ-45 AUDIO - AUDIO : Audio COM 1 - COM 1 : Serial Port 16550A / DB-9 pin male SPDIF_OUT - SPDIF_OUT : Audio / CD-ROM Sound Input SPDIF_O12 - SPDIF_O12 : Audio / CD-ROM Sound Input IE1394_1 - IE1394_1 : FireWire/1394 IE1394_2 - IE1394_2 : FireWire/1394 SATA1 : SATA SATA2 : SATA SATA3 : SATA SATA4 : SATA SATA5 : SATA SATA6 : SATA PRI_EIDE : SATA ESATA : SATA USB78 : USB / USB USB910 : USB / USB USB1112 : USB / USB FLOPPY : Floppy Disk CD : Audio / CD-ROM Sound Input AAFP : Audio / Mini-jack CPU_FAN : None PWR_FAN : None CHA_FAN1 : None CHA_FAN2 : None Performance Tips Notice 224 : SMBIOS/DMI information may be inaccurate. Tip 2511 : Some memory slots are free so the memory can be easily upgraded. Warning 2523 : Memory bus speed exceeds memory rated speed. Reduce memory bus speed. Tip 2 : Double-click tip or press Enter while a tip is selected for more information about the tip. --------------------- More to come -Ryan |
I can send more of the report, I suppose that's enough for now.
Also, I did try the HD Core card in each of the 2 PCIe slots with the same result. Also, I'm on 7.4cs8 (says cs7) I did have 3x UAD-1 cards in the PCI slots, but I removed those for testing and haven't put them back yet. The results were the same with or without the UAD cards. I tried standard SATA mode and AHCI for the drives. Same result for each. Thanks, Ryan |
Bump and update:
New motherboard - ASUS P5Q. Similar specs but P45 chipset instead of the P43. Still the same issues. Tried recording 32 tracks and 96k - same problem. 32 tracks at 48k = same problem, but longer between glitches - a little more than 2 secs between each glitch. It always starts glitching at different times, but once it starts it continues until the end. Sometimes it takes 45 min of recording to start glitching, sometimes 2 minutes. Also, this mobo has an additional SATA port on a Marvell/Silicon Image chip, but it is basically a raid only port. I did try it there to see what happens. It did start glitching after 4 or 5 minutes, but the whole system froze up after 70 min of recording on the drive attached to that port. hmmmm.... -Ryan |
Hey Ryan, Sorry to hear about the troubles.
I experienced clicks, pops, and crackles with glitches and it turned out to be a bad A/D expansion card in my 192. Also I have had a hell of a time with my HD2 and my asus/quad core combo...ghosts in the machine for sure. Try some of these: 1. if you can, try moving the core card to a different slot. 2. go into your system preferences, harware, and disable parts of your system you arent using like extra usb, sata, firewire, network ports. (you're trying to free up IRQs) try and get it slimmed down to rediculous perportions and then add them back in until it errors again. (if it helped in the first place) good luck! Justin |
Thanks Abomb97.
I'll try getting rid of everything next. I did a fresh install of windows, then PT 7.4 and tried with nothing else installed and the problem is still there. I just did a new test. I attached an IDE drive to the PATA port and tried that and it went for 30 min without any glitches. I'm currently doing that test again for longer period -hour and a half or so- to see how it works out. If this test works fine, then it seems to be isolated to drives on the SATA ports only. Just to clarify, this isn't an issues with regular cracks and pops from faulty digital i/o or clocking issues, etc. Once it begins glitching, the timing of the glitches is consistent. Sounds like a little "pop" repeating, like a bad edit at the top of a repeating loop. I think it's related to buffers and writing chunks of data to the drive. Also, it is NOT present while monitoring the recording in progress. But after stopping record and playing back the sine wave tones that were recorded, it's there. Thanks again! Peace, Ryan |
Just ran across your posts here. I haven't seen this issue for a while but I realized I haven't done much recording that required more than 8 tracks of input (been doing overdubs, editing and mixing lately). The comment about the 192 AD expansion card got me thinking as this problem occurred while tracking drums (using more than 8 AD inputs on my 192). Perhaps it is a fault with the 192 AD expansion card, or at the very least a bad connection between the add-in card and the 192IO? Maybe some contact cleaner on the exp card would be something to try?
Digital noise and glitches when recording to gdrive | antward | Pro Tools M-Powered (Mac) | 2 | 05-13-2011 07:43 AM |
Popping, clicking, stops and glitches with recording and playback m powered 8 | Krisdavid | Pro Tools M-Powered (Mac) | 5 | 03-29-2010 02:55 PM |
MBox 2 Pro recording glitches/clicks - how do I avoid? | Jhaos | General Discussion | 1 | 02-11-2008 06:30 PM |
Battery 3 Audio Glitches | thebends9 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 02-07-2007 03:41 PM |
Audio Glitches | syMPh | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 05-17-2002 01:38 AM |
