Is there a way to simultaneously record 16 tracks or more, in Pro Tools?
I have had this problem, and the most I can record is two tracks. How can I record up
to 16 tracks or more, at the same time? Are there any other equipment I have to add/buy, or can it be done by sending the 8 ins on the 888|24 IO to my mixer? Will that work like an 8 track recorder in Pro Tools? If I did that, will I be able to record 8 seperate tracks at once? And if I added 2 more 888|24s will it work like a 24 multitrack recorder? What about with an ADAT? Thanks in advance. ------------------ NigMa Productions - Let us produce your next hip hop tracks, or demos. http://www.mp3.com/tycoon
NigMa Productions - Let us produce your next hip hop tracks, or demos. http://www.mp3.com/tycoon |
Re: Is there a way to simultaneously record 16 tracks or more, in Pro Tools?
PT|24 can record up to 32 simultaneous tracks. PT|Mix can record up to 64. You can add more interfaces to allow more simultaneous inputs up to a maximum of 72.
-Mike Rockwell |
Hi Tycoon,
The following information is based on the assumption that you are recording in Pro Tools for NT. First let's focus on recording 8 tracks simultaneously since the 888|24 does this by design. Create a new session and add 8 new tracks. Go into the mix window and look at the channel strips. The first channel should say "#1/1|888/", the second "#1/2|888/", the third "#1/3|888/", and so on for the eight channels. These are the inputs for the channels. By record enabling all 8 tracks, you can record 8 tracks simultaneously. In order to get output out of the other ports, you must select the output in the channel strip. Click on the "#1/12|888" button on the strip and set the output to the appropriate output. To achieve more channels such as 16 or 24, add another 888|24 to the system, making sure to connect them to the cards and slave them via superclock. J. Wolf Digi Tech. Supt. |
Thanks for the info, exactly what I wanted to hear. I knew it was possible. Also which is better 888|24 or Motu 2408? My friend is building his studio, and I was trying convince him that the 888 were better, but he proved my wrong. Can you
even use Motu 2408 and protools together? ------------------ NigMa Productions - Let us produce your next hip hop tracks, or demos. http://www.mp3.com/tycoon
One question rings - have you taken some time to read the installation guide?
The answers to your questions are right there. |
How to record more than 4 tracks simultaneously with mbox 3 pro | huggy | Pro Tools 9 | 16 | 01-12-2012 06:59 AM |
how many tracks can you record simultaneously? | mojovoodoo | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 03-29-2007 12:17 AM |
how many tracks can you record simultaneously | guy.fi | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 11 | 04-06-2004 04:02 PM |
You can record 8 tracks simultaneously with digi 001 right? nt | MaKoRancid | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 03-02-2003 02:21 PM |
Is it realistic to record 32 tracks simultaneously? | Jeff D. | Pro Tools TDM Systems (Mac) | 3 | 11-30-2000 08:10 PM |
