Writing Plugins to the Track
I'm finding that as I mix a track, I'm adding in lots of compression and eq plugs (in real time) and was wondering if anyone had found an easy way to write these to the track after everything is perfect (to save DSP).
What I've been doing is bouncing the tracks to disk individually and then building a new session out of them. This works, but it's just messy. Maybe I'm just being whiny, I dunno. Thanks. |
Re: Writing Plugins to the Track
You can route the output of the track to an unused bus, then create a new audio track with that bus as an input. Record the audio on the new bus. Unfortuantely this uses more of the limited buses available in PTLE, but it is doable.
Check out Audiosuite plug-ins. Thats what they are there for.Once you have the settings on your compressor or EQ set, save the settings.Select the same Plug-in from your Audiosuite menu.Load the saved setting.Apply the effect.It's very easy.Read the manual for a more info.I know my instructions are not very detailed.Hope this helps!!!!!
Thanks, smmdrum, I'd thought of that, it's just that I use so many plugins on so many different tracks that it would take a while to print them all. It's all doable...just looking for ways to save time. Thanks for the suggestions, guys!
Continuously writing (or tapping) tempo track in real time | stevegalante | macOS | 3 | 04-22-2013 08:03 PM |
Tech Specs for writing ProTools Plugins | SolidStateSnake | General Discussion | 5 | 12-06-2012 08:56 PM |
waves plugins writing unwanted automation on playback | jmattchan | Post - Surround - Video | 13 | 07-17-2009 01:50 AM |
Structure newbie question, writing instrument track to audio | Mike Emerson | Virtual Instruments | 4 | 05-07-2008 01:19 AM |
How to Bounce Plugins to the Track? | tpp | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 08-23-2006 08:17 PM |
