Go Back   Avid Pro Audio Community > Pro Tools Hardware > FireWire and USB Audio Interfaces (Mac)
Old 11-16-2015, 09:40 AM
aicragleon aicragleon is offline
Default Does an unbalanced input to Mbox Pro (3rd gen) become balanced output?
If I plug in a cd player or such to the unbalanced RCA inputs of an Mbox Pro 3rd gen, do the outputs of the Mbox from the TRS output using a TRS cable become balanced to say a Yamaha HS50M that accepts TRS balanced input? What about an unbalanced TS input? Does that signal become a balanced output to the studio monitors? So does the Mbox Pro perform the duties of a DI box where the unbalanced signal gets converted to a balanced signal?
Old 11-16-2015, 09:49 AM
YYR123's Avatar
YYR123 YYR123 is offline
Default Re: Does an unbalanced input to Mbox Pro (3rd gen) become balanced output?
The short answer is Yes....
Daniel
Mbox 2 Pro - Unbalanced/Balanced Inputs Dstryr FireWire and USB Audio Interfaces (Mac) 0 04-25-2013 04:19 AM
1/4" Balanced Output Jack to 1/4" unbalanced aux input heaphone amp edgarbc1 General Discussion 4 12-13-2010 10:00 PM
192 I/O unbalanced input in a balanced setup AC Sound Pro Tools TDM Systems (Mac) 5 11-25-2009 01:25 PM
should I buy balanced TRS or unbalanced TS (Mbox) ITZIK 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 04-20-2004 10:38 AM
Should switch from unbalanced to balanced mic input? el biciclista 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 03-16-2002 10:10 AM
