Old 01-25-2010, 07:51 PM
mike59271 mike59271 is offline
Default How do i go back from 8.0.3 to PTLE8?
I've been experiencing an onslaught of memory errors and white noise problems and just read that im not the only one. Instead of trying to get this all to work I would rather go back to the basic PTLE8. How do i go back to it?
If it helps, i reformatted my computer, installed pro tools then all of my VI's and plugins then i upgraded. Do i have to do a fresh re-install plugins and VI's included? Thanks for the help guys
Edit: It looks like i need to go to a previous image when 8.0.3 was not installed. I never made an image of my drive so does this mean a fresh reboot of XP and all else is in order? I really dont care what i have to do, i just want this stuff to work...
Old 01-25-2010, 08:24 PM
Shan's Avatar
Shan Shan is offline
Default Re: How do i got back from 8.0.3 to PTLE8?
It's best to start fresh. Trying an "uninstall" will still leave some residual stuff behind at times. Take this opportunity to create images along the way. Right after XP is installed, immediately do an image. Install all your drivers, then do another image. Do the standard optimizations for PT, then do another image. Install PT and again, do another image. Finally, install your plug-ins and do a final image. If you need to do future trouble shooting, these standard images will have you up and running again in no time. It's also good to install new versions of Pro Tools to your restored optimized PT image as apposed to installing "over top". Acronis True Image is popular but not the only one.
Shane
Pro Tools Power User Editing
Give your plug-ins a facelift...and skin 'em!
"Music should be performed by the musician, not by the engineer."
Michael Wagener 25th July 2005, 02:59 PM
Pro Tools|HD Native 9.0.1 | Pro Tools|HDX 10.2 | Studio One | REAPER 4.22 | HD OMNI | HoboMac Pro 2.26Ghz Quad-Core | W7 Ultimate 64-bit
Old 01-25-2010, 08:35 PM
Thank you very much for the informative reply. I was leaning towards a fresh reboot anyways. Here's another question for you, When you say "standard optimizations for Pro Tools" what do you mean? I'm running XP (SP3) Do you mean just basic Windows tweaks? Also, Ive got a bunch of VI's (Best Service, BFD, Komplete etc...) Plus plugins, should i be creating an image before and after each new VI install or just after the whole thing?
Also, I was under the assumption that the first programs to be installed after a fresh reboot of windows will run the fastest and more efficient which is why you go with your drivers then your most used programs and so on, will installing true image before anything else make any noticeable effect? Thank you very much for your time!
Edit: also, i know i come off as a total newb. But is 8.0.1 the same as the hard disk version i got when i bought it? Or is that an upgrade? Should i just install the disk that came with my Mbox 2 and stay away from any updates?
Old 01-25-2010, 09:51 PM
TOM@METRO's Avatar
Shane can add to this but...
Yes
You can't be too safe or careful.
I install True Image right after the chipset drivers.
8.0.1 is an update for 8.0 and has worked well for most of us.
~ tom thomas
Formerly hobotom
Pro Tools Ultimate 2019.10 HDX
HD Omni and 192 I/Os
Windows 10
Intel Hexcore i7
All Samsung Pro SSDs
Ampex MM1200 2" 24 trk tape
www.metrostudios.com
Old 01-25-2010, 11:44 PM
Shan's Avatar
I mean the Digidesign suggested Pro Tools optimizations. Avoid the "geek tweaks" until you know your system is running solid. The geek tweaks add to many variables if it ever comes down to trouble shooting problems and getting Digidesign to reproduce bugs in house.
I myself do an image before and after all plug-ins are installed. I don't do images after each plug-in.
I install XP(no drivers) then True Image and do an image. Then I'll install drivers, do an image and take it from there. You can also do an image without installing True Image. This can be done via another partition with an OS on it and by the CD bootable version of True Image.
Shane
Old 01-26-2010, 12:27 AM
Default Re: How do i go back from 8.0.3 to PTLE8?
Thanks for the heads up, I'm gunna go at it tomarrow and report back with my results. I wasn't able to find the Digidesign Optimizations for XP only Vista.
Old 01-26-2010, 10:35 AM
DigiTechSupt's Avatar
A search for 'Windows Optimizations' in the Knowledgebase turns up what you're looking for:
http://avid.custkb.com/avid/app/self...+optimizations
Avid Audio Tech Support
Support FAQ
first mac pro to ptle8.3 redchair 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 11-14-2011 09:12 AM
Using PTLE8 without 11R? aaron.ferrer Eleven Rack 1 10-05-2011 04:47 PM
MCU Pro and PTLE8... help! cwhite771 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 11-05-2009 07:29 AM
10.5.7 and PTLE8? Overlord of the Undertone 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 06-01-2009 11:50 PM
PTLE8 and Mac Pro? kastadyne 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 12-24-2008 11:03 AM
