Old 08-07-2009, 12:31 PM
earworms earworms is offline
Default long delay when recording or playing back
Hi there.
I've had a look through previous posts, but can't find the right answers, or they are so complicated I don't understand them as I am not a very experienced audio gear user. Maybe someone can help me?
I am using an 002r / PT 7.3.1 on a Powerbook G4 running OS 10.4.11 recording onto an external LaCie 500 firewire drive currently daisychained to the 002r (though have tried the 800 port from the powerbook too).
I want to record up to 12 channels, no plug ins are being used.
When I press record there is a long delay, up to 30 seconds sometimes, and then recording goes ahead. Once it records it all runs smoothly. I have the same problem with playback.
Sometimes I get the 6086 error message, sometimes I get 9128. I have tried decreasing and increasing H/W Buffer and CPU Usage to see if there's a difference, but all settings seem to be the same?
Any ideas anyone? Thanks!
Old 08-07-2009, 02:04 PM
daeron80 daeron80 is offline
Default Re: long delay when recording or playing back
Try changing Record Allocation. It's in prefs under the Operation tab, right hand side. Open-Ended Record Allocation: tell it to limit to, say, 10 minutes, or whatever you think you might need in the longest cases.
David J. Finnamore
Nyquist was right.
PT 2019.10 Ultimate | Omni | macOS Sierra
PT 2019.10 | Saffire Pro 40 | Win10
Old 08-07-2009, 03:01 PM
thanks! that's a good idea. i will try that.
Long delay before playing/recording wfenlon 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 01-22-2013 11:54 PM
Long delay before playing/recording wfenlon 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 01-19-2013 07:58 PM
Distortion of Recording When Playing Back Recording acs Pro Tools M-Powered (Win) 2 03-18-2008 05:29 PM
Long Delay before recording starts. Hekler 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 06-19-2004 03:17 AM
really long delay before recording begins Joseph Grimm 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 11-09-2000 01:09 AM
