Old 08-05-2009, 06:39 PM
earworms earworms is offline
Default HELP! can't connect to 002 rack
Hi there.
I have just borrowed a friend's 002 rack which I need for a project on Sunday. I myself normally use an Mbox 2 / PT 6.8.1 on a Powerbook G4 running OS 10.4.11 all of which works a treat usually.
My friend tested the rack (on his PC) before handing it to me and we know the unit works fine.
But when I plug it into my G4 no connection is established.
Do I need to upgrade / downgrade the firmware? Do I need to instal a different version of PT? Is it possible to download this from Digidesign? My friend cannot find the Mac disk that came with his rack...
Thanks for any help!
Old 08-05-2009, 06:48 PM
Default Re: HELP! can't connect to 002 rack
This seems to happen to Digi002/002Rs and is related to the Power Harness issue (do a search and you'll find a lot of posts about the Power Harness). For some reason moving the unit seems to trigger the problem for some people.
Obsidian Dragon
Model Name: MacBook Pro
Model Identifier: MacBookPro14,3
Processor Name: Intel Core i7
Processor Speed: 3.1 GHz
Number of Processors: 1
Total Number of Cores: 4
L2 Cache (per Core): 256 KB
L3 Cache: 8 MB
Memory: 16 GB
MacOS 10.14.6 running Protools 2019.10.0
Old 08-05-2009, 06:55 PM
PT 6.8.1was an interim version for Mbox 2. Does anyone know that it works with the 002?
Old 08-06-2009, 01:37 AM
thanks guys. i will look through all of the DUC for answers when i get back from work today, but in the meantime some of you might easily be able to answer two questions:
power harness - would a powered firewire hub make any difference? or is the power harness problem an issue with the rack unit itself?
software - my friend whose rack it is uses PT 7.3.1 but like i mentioned in my initial post, he can't find the mac disks. is it possible to download 7.3.1 from digidesign's webpage? their website is so chock full of info, i find it quite hard to navigate.
thanks again.
Old 08-06-2009, 04:58 PM
Just thought I'd post a little update here: I managed to get hold of PT 7.3.1 and now the 002 rack connects beautifully with my G4 powerbook. No problems.
Old 08-06-2009, 10:23 PM
thanks again.
Glad you got it working
To answer your questions, the power harness issue has or will hit most every 002 or 002R before a certain serial number. Firewire hubs are NOT recommended. If your friend has registered his PT software, he should be able to download the version for either platform.
Old 08-06-2009, 11:38 PM
flommer flommer is offline
Same goes for USB hubs for any MIDI or other ProTools related connections in your studio.. They seem to introduce random connectivity issues and I personally will avoid hubs at all costs... If I ever need additional FW ports I'll add a PCIe card..
MacPro3ghz, 6GB, 10.7.5, PT10.3.2, Digi002 factory/toolkit2/PTIEP, 11R
Old 08-07-2009, 03:26 AM
The Dougfather The Dougfather is offline
6.8.1 was only made for the MBox 2 Pro.
You need at least 6.9.2 or i'd recommend 7.0 for your config. I couldn't get 6.9.2 to work on my powerbook.
iMac i5 2.8GHz, Macbook Pro 2.4GHz, Pro Tools 10/11, MOTU 828mk2, Presonus Digimax FS, Presonus Firestudio Project, TC Konnekt 24D
iCON Photography
Eleven Rack won't connect spandol Eleven Rack 2 02-02-2011 09:32 PM
I can't get my g5 to connect to my 003 rack!!! PhillyFresh Pro Tools TDM Systems (Mac) 2 02-12-2009 11:15 PM
002 rack clicking cannot connect roainfo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 02-17-2007 03:46 PM
digidesign 002 rack won't connect-help!!! muscmp 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 08-07-2006 12:46 PM
002 Rack Can't Connect to PC Steel City 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 02-13-2006 02:38 PM
