Go Back   Avid Pro Audio Community > Pro Tools Hardware > FireWire and USB Audio Interfaces (Mac)
Old 07-08-2016, 06:11 AM
AgentGFunk AgentGFunk is offline
Default Direly need help - FW bus reset in Pro Tools 8 with 003
I posted this yesterday with absolutely NO response at all.
I'm beginning to think this is totally hopeless.
I've tried everything I can think of - reinstalling software, switching cables, switching ports, etc.
I can't get this thing to stop doing one of three things -
-H/W buffer usually says it's underflowed and I need to increase buffer size
-Pro Tools quits unexpectedly
-And MOST often, there is a firewire bus reset
I'm almost positive all these things are related to the same problem.
Does anyone have ANY ideas?
Old 07-08-2016, 06:43 AM
YYR123's Avatar
YYR123 YYR123 is offline
Default Re: Direly need help - FW bus reset in Pro Tools 8 with 003
You need to provide specifics of your OS, hardware, along with specifics of PT version and interface
Since this is an older setup it won't get as much attention as a newer setup, just the way it is.....however it was most likely caused by lack of useful and pertinent info about your setup
We await your response
Daniel
Old 07-08-2016, 07:10 PM
Sorry. I will add this now.
I'm running:
Pro Tools 8.0.5 with a Digi 003 interface. It is running with Snow Leopard Version 10.6.8. It has an Intel QUAD Core (I'm pretty sure it is Quad, not Dual) Xeon Processor in it and 16 GB of RAM.
Old 07-08-2016, 07:11 PM
I'm sorry and I'm running a Mac Pro. It really is a pretty high-end set up. The really PROSUMER setup of its time. Why I'm confused. :/
Old 07-08-2016, 10:40 PM
YYR123's Avatar
Is this a Mac Pro 3.1?
What are the hard drive specs, and by specs I mean format of connectors and cache size.
Have you tried repairing permissions?
Have you tried trashing preferences ?
Daniel
pro tools click reset adamcheese Pro Tools 10 2 09-19-2012 08:16 PM
Reset Pro Tools Memory? acacia Pro Tools TDM Systems (Mac) 1 11-10-2010 09:19 PM
pro tools has reset the sample rate of the hw device because it was changed by anothe GHoSTFiNGeR Tips & Tricks 2 03-05-2010 11:13 AM
Pro Tools region counter reset marcnyc Pro Tools TDM Systems (Mac) 7 02-06-2010 08:23 AM
003 rack reset when starting pro tools after being idle jesseblu 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 02-16-2008 11:52 AM
