JL COOPER Surround Panner with MIDI io is making me crazy
Hello everyone, I feel like I have tried everything, so any sort of advice would be greatly appreciated right now.
We have a D-Command es with 24 faders, HDX Pro Tools 10/11 and a MIDI i/o on a 6 core Mac Pro running Mountain Lion. We have had the JLC panner since about HD v7.4 or 8. All of the knobs have always functioned fine but every once in a while, with no warning or anyway to make sense of when it goes (i.e.: no software has changed at all) It will let you pan ONLY from the very FRONT L to just slightly back and hard right. The actual position of f/r balance will go from +100 to +42 no matter what you do with the stick itself. If you move it directly back and forth, there will be almost no movement at all on screen. It also seems to be locked in a curve from very top left to +42 f/r on the right, no other path. I just went through the nightmare fighting to get my MIDI io to be recognized by AMS (after mountain lion upgrade and PT 10/11 install the whole io dropped off the system) - only by installing the v9.0 MIDI io divers and doing the firmware update that came with PT11. weird, but whatever. I would suspect hardware problems except for the fact that I am pretty sure that some random time in a month or so, it will suddenly work just fine as if nothing was ever wrong, that has kinda been the MO of this panner. Any Ideas? |
Re: JL COOPER Surround Panner with MIDI io is making me crazy
I'll guess hardware problem. I still use mine on PT10 and do not recall seeing behavior like that.
It might be a problem with touch sensitivity from a broken wire to the joystick. There is a wire that runs through the inside of the metal stick. It kinda sorta makes a friction contact with the stick where two parts of the metal stick are pressed together. Without contact, the circuit does not know you are touching the stick and no position data is sent. It might be that the wire inside is broken and only makes connections at certain stick angles.My description may not make a lot of sense until you take the unit apart, and I'm working from a memory of when I repaired mine 3 or 4 years ago. |
You know, in my manic research on the duc I think I came across a post of yours talking about this. I figured this is going to require a screwdriver and a modicum of adventure.
The problem is so random and intermittent I was hoping for a quick "pref trashing and PRam reset" or something, but what kind of fun would that be? Thanks for the quick reply |
I too use the panner in 10.3.8 HD|6 TDM ACCEL (OSX 10.8.5) and have not seen this problem. Make sure you have the "latest" profile
http://avid.force.com/pkb/articles/e...nload/en355431 Also, verify your MIDI is working properly. Then, verify that the powere adapter is functioning properly. If you believe all that is, and you sill have problems, contact JL Cooper support.
Tom Hambleton CAS Ministry of Fancy Noises IMDb Undertone on Facebook Undertone Custom Sound Libraries "Groupable markers would be epochal!" -Starcrash |
Surround panner by JL Cooper | peter5992 | Post - Surround - Video | 6 | 09-10-2013 09:37 PM |
Use JL Cooper Surround Panner without Control Surface | banamsclc | Post - Surround - Video | 6 | 04-05-2013 06:08 AM |
JL Cooper Surround Panner Not Working | paranoia | MIDI | 0 | 09-09-2008 11:53 AM |
JL Cooper Surround panner...?? | P A M | ICON & C|24 | 4 | 11-03-2006 02:30 PM |
New JL Cooper Surround Panner | 1150Post | Post - Surround - Video | 7 | 05-09-2006 05:01 AM |
