NEVE, MANLEY, TUBE TECH, SYTEK!!!!!
IF ANYONE IS USING THESE OR ANY OTHER HIGH END PRE-AMP,
HOW ARE YOU HOOKING IT UP TO YOUR DIGI 001 OR 2??????? I JUST GOT TUBE TECH MP1A AND IT ONLY HAS XLR OUTPUTS, AND THEY ARE EXTREMELY HOT!!!! I TOOK 2 XLR OUTS AND WENT INTO THE FRONT OF DIGI 001 WITH THE GAIN ALL THE WAY DOWN AND THE PAD ON. THIS WORKED OKAY BUT THE SIGNAL WAS STILL A LITTLE HOT. DOES THIS DEGRADE THE SIGNAL IN ANY WAY??? I TRIED ACC GUIT, ACCORDIAN, AND VOCALS. IT SOUNDS AMAZING. BUT ALSO I DONT WANT TO BE LIMITED TO THE XLR OUTS SINCE MY WHOLE STUDIO IS 1/4". I HAVE A BERHINGER PATCH BAY. I TRIED AN XLR TO 1/4" CABLE OUT OF THE TUBE TECH BUT IT WAS JUST TOO HOT. IS THERE SOMETHING TO KNOCK IT DOWN BUT KEEP THE SOUND. WHAT ARE YOU GUYS USING???????? THANKS |
Re: NEVE, MANLEY, TUBE TECH, SYTEK!!!!!
READ THE MANUAL AND STOP USING CAPS BUT I THINK THE ANSWER TO YOUR PROBLEM IS TO USE SOME CABLES WITH AN XLR CONNECTOR ON ONE END AND A 1/4 TRS-JACK ON THE OTHER SIDE YOU GET IT SO HOT BECAUSE INPUT 1&2 ON THE DIGI001 ARE MICROPHONE INPUTS IE MICPRRE'S I DONT SEE WHAT MANLY AND MYTEK HAVE TO DO WITH IT I HOPE YOU DO UNDERSTAND THIS WAY OF WRITING IS LIGHTLY TIRING BUT YOU MUST READ IT TO UNDERSTAND WHAT I WROTE
So please, use interpunction and only Caps where the are supposed to be...
What's that? - That's the machine that goes "pling". Bastiaan |
If you're using an external preamp, you should use the Line Inputs on the 001, as in inputs 3 through 8, then conrol the input gain via PT. I also think you need to read up on gain staging and similar things, otherwise you're highly jeopardizing the TubeTech's sonic capabilities, which would be a shame.
www.myspace.com/krou |
Well you know .. the thing is that you're jeopardizing Tube-Tech's capabilities only by running it through Digi001's [bleep] converters (no offense Digidesign..but I guess you agree). Buy some Swissonic converters, which are cheap and rival Apogee Rosetta! Swissonic AD24 should be a good choice and you can connect it to Digi001's ADAT input - the Swissonic WD8 would also be a good choice as masterclock, which would reduce jitter even more
*pssst* the one and only mighty Elliot Scheiner uses Swissonic gear .. can't be bad
High End Preamps (Neve 1272 Pair, Manley Slam!, Tube Tech MP 1A) | Eduardo Apolonia | Buy & Sell | 2 | 03-05-2014 08:56 AM |
Manley Voxbox or Neve Portico II | spiritfallrecording | General Discussion | 6 | 11-02-2013 06:09 PM |
Tube-Tech CL 1B NewVersion 1.1.1.1 | K.I. | Pro Tools TDM Systems (Mac) | 0 | 12-10-2008 11:35 PM |
New Tube-Tech CL 1B plugin for HD ! | Dutchmuzik | Pro Tools TDM Systems (Mac) | 17 | 03-29-2007 03:21 PM |
Tube Tech MEC 1A - your opinion? | Kuba Pietrzak | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 12-03-2002 08:44 AM |
