Basic questions
Hi. Just learning PT (using vers. 11) and would like to know if there is a way to Pause play. Also, when I import audio (and choose Add), is there a way to tell later where the audio came from (some sort of path). I was told Disk Allocation will show that, but doesn't. So I can't seem to tell where the audio was added from? Or, to avoid confusion, should imported audio always be copied?
Thanks! |
Re: Basic questions
Yeh you're best to set preferences to copy files on import! this eliminates the potential for files to go missing from the session when accidently deleted from their original location. To pause playback use the space bar! if you want the session to pause at the place where you stopped then press the N key on your leyboard and it will stay wherever the timeline is stopped. press N again and it will revert back to where playback was started Chris
Re: Basic questions
Thanks for the info!
Newbie questions on laptop PC selection - basic questions - thanks... | half drag | Windows | 0 | 01-04-2011 01:12 PM |
...some basic questions needing basic answers | aponceenrile | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 01-12-2010 10:48 AM |
RAM - basic questions | jlcnyc | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 8 | 10-30-2004 10:34 PM |
A few basic questions | K.B. | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 11 | 05-09-2004 02:50 PM |
just a few basic , I should already know questions. | rockwellcreek | Tips & Tricks | 2 | 10-07-2001 09:21 AM |
