Routing Kontakt as a multi timbral instrument
Hi Folks,
I'm trying to route Kontakt as a multi timbral instrument in PT 10. Please see screenshot 1. In this photo "Kontakt st 2" appears in the plug in section for this track and is on top and checked. In screenshot 2, I should see "Kontakt st 3" but "Kontakt st 2" is my only option... Why?? This is driving me nuts! Thanks for any help. Cheers, walter |
Re: Routing Kontakt as a multi timbral instrument
Nobody knows??
Hi Folks,
Setup in Kontakt's I/O for st2, st3 etc...
Depending on your version, this use to be in standalone first. Save as default.
(Help us Help You)<<<click here Profile-System Tracks: https://www.n1m.com/datatunesdetroit Apple Music https://music.apple.com/us/search?term=DatatunesDetroit |
Thanks for you answer. I already have 3 tracks set up in Kontakt. On the screenshot, you can see them at the bottom.
It's hard to tell from the screen shot, but if you look to the left of the "Kontakt st 2" for each track, it should say something like "inst 1" for one track, and "inst 2" for the other. The "Kontakt st 2" would then be correct for each of the plugin sources. Kind of confusing, but that may be what's going on.
Help Us Help You ______________________________________ Chris Pro Tools 2024.3 Focusrite LS56 Focusrite Pro40 (2) TC Electronic Studio Konnekt 48 Avid Artist Mix/Control Slate Digital VRS8 Analogue Tonebuss 24 Channel UAD-2 OCTO Core Accelerator UAD Volt 2 macOS 10.15.7 32 GB DDR4 RAM 4.01GHz Quad-Core Intel Core I7 NVIDIA GeForce GT 740 2 GB |
Your screenshots are blurry and unreadable. If you can't get this sorted on your own email me at my forum email address and I'll send you a pair of output.config files that will give you 8 and 16 stereo outputs in Kontakt.
Thanks music man, would you mind if I sent you an email with a clearer pic of what's happening?
Thanks, that's not the problem but I appreciate the answer!
So, starting with the basics ....
Within Kontakt itself, how many 'st' outputs have you created? I find it convenient to set up 16, and there is an option (onc you've created them) to set the current configuration as the default. Assuming you have created multiple outputs within Kontakt, AND have loaded multiple sounds within Kontakt, have you set each sound within Kontakt to respond to a different MIDI channel and to send the audio to a different Kontakt output? Only then can you properly set up Kontakt within Pro Tools to be a multi-tmbral instrument with each Pro Tools Instrument Track sending MIDI to a different sound, and receiving the relevant audio (only) back into the instrument track.
Mac Pro 2009 with 2010 firmware, 12-Core 3.46ghz, 64gb RAM & working Thunderbolt, OS 10.14.6 and Windows 10 iMac 2012 27", 3.4ghz i7, 32gb RAM OS 10.14.6 Digi 003 Console for control surface only, Focusrite OctopreLE and MOTU Traveler for extra analog-ADAT conversion, UAD Apollo Quad Silver with Thunderbolt card, Apollo x4 and pci-e Octo, Adam A77X monitors. Pro Tools 2022.4, Media Composer 8.9, Sibelius 8.7, Cubase Pro 11, Wavelab Pro 11, Logic Pro X 10.5.1, Mainstage 3. Various apps, soft synths, FX plugins. Plenty of hardware synths, rack gear, microphones etc. And then there's the studio ;-) |
Routing Kontakt as a multi timbral instrument | walt68 | Pro Tools 10 | 8 | 04-30-2017 04:35 AM |
Kontakt multi. | walt68 | Virtual Instruments | 11 | 06-17-2014 03:58 AM |
Problems with Xpand2/Midi multi-timbral control | simpke | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 03-22-2014 08:19 AM |
roland fantom xa multi timbral setup going wrong where? ? | billynojokes | MIDI | 0 | 07-07-2010 05:31 PM |
reaktor multi-timbral? | Bryan | Pro Tools TDM Systems (Mac) | 6 | 09-26-2001 06:17 AM |
