Re: Error -6101 when recording
Or there may be a conflict. Are your Merging drivers the latest version?
Dell Precision 490 Workstation, dual 4 core 5355 Xeon, 16gb Samsung DDR2 ECC Ram - Windows 7 Ultimate - Nvidia GTX 650 - 3 x Internal WD Blacks - PT 2018.3 - Digi 002R - Original Mackie HUI - 3 screens - JBL Monitoring. Dell XPS 8700 i7-4790 - 24gb RAM - Windows 10 - Nvidia GTX 1060 6GB with Studio driver 546.01 - 2 x Internal Samsung 860 EVO SSDs, and MSATA card - Davinci Resolve Studio 18.6.4 - 3 screens - Blackmagic Speed Editor - MK1 Presonus Faderport - Canon C100 mk2 - Atomos Ninja 2 - Zoom H2n |
Yes they are
A Spinner Drive is only fast on its outer rim with the fist 16 GB. Depending on how full the drive is - your speed will vary. 2) You could try to connect it to Thunderbolt which is a lot more consistent than USB. Latter is nice for copying etc but for Real-Time-Critical-Applications you should not rely on it. It might work and it might NOT. In my case latter has proven to be something that always occurs ;-) USB as I understand it 'Passes Thru' the CPU where Thunderbolt does - but I might not be correct. Please research that. A couple of things to try 1) Lower your Buffer to at least 256 or better 128. Only up it when using A LOT of plugs. 2) Try to record to the system drive of your Mac. That SSD is faster than anything you could hook up as peripheral. It is insanely fast. At least twice as fast as an SSD hooked up via Thunderbolt and orders of magnitude faster than anything USB. And see if the error occurs there. if it does - Your issue is definitely NOT drive related. If it does NOT - your 7200 Spinner is the cause or the USB3 connection feeding it. Swap to TBOLT and ONLY use USB3 for non-critical work like Sample Storage etc. While I get a lot of these error with VIs - I never get them with just audio. Protools in that regard in my studio is rock solid. Unless - it cannot get files fast enough off or to the drive
2016 MacBook Pro Retina | 16GB RAM | 1TB SSD | OS X Latest - PTHD 12 Latest | 4K LG Thunderbolt Display | Logic Pro 10 |
I'll make tests. I'll record on integral SSD. Also I'll record less channels on my external drive and watch how it works. |
Well, I did some tests coming out from advices I received here.
Problem still exists! I have recorded on my integral SSD. Recorded less channels, but recording stops anyway. I just want to find out reason, why it happens. Do I have to change my computer or may be DAW? As it doesn't work with my 6k Merging audio interface. ( Please! Thank you! Sent from my iPhone using Tapatalk |
#16
There is one more thing:
I never had problem when I was working with older versions of Protools. Like 12.6 I just couldn't find an old installation file. I would be appreciate if someone helps me to find 12.6 version of Protools. Thanks |
#17
Create a support case
HELP! -6101 errors while recording on PT 11.0.2 OS 10.8.5 | neil_mcdermott | macOS | 3 | 10-29-2013 10:17 AM |
6101 error on bounce (not while playing or recording) | pkm | macOS | 11 | 09-22-2011 04:55 AM |
Error Message 6101 when recording and playback | Mattslash | Pro Tools M-Powered (Mac) | 2 | 10-07-2010 03:13 AM |
Error 6101 while recording to Internal Hard Drive on Mac Pro | KeithKenny | Storage Subsystems | 2 | 02-10-2010 09:21 PM |
