Re: Purpose of Outputs on HD IO 16x16 Analog
Yes the analog controls are for cotrolling MONITORS, and it has absolutely no relevancy for what happens in the PT session. Those are two separate things, completely.
Essentially, yes. But it also has a monitor controller built in
You will still need to use a minimum of 2 of your 16 outputs to feed the stereo signal from Protools to the C24 monitor inputs. The only way your C/24 can control your monitors is from a stereo feed from Protools out of your 16 I/O connected to the monitor inputs of your C/24.
Feel free to PM me, we can set up a phone call where I can walk you through all of this.
HD Native Pcie, PTHD 11, PT12 Vanilla, Omni, Lynx Aurora 16, 192 I/O (16 in/8 out), 24 Fader D-Command, lots of preamps and compressors. MacPro 5.1 (12) Core (2009 MacPro 8 Core Upgraded to a 12 Core MacPro), 56 Gig Ram, SSD System & 3 - 2TB Drives, OSX 10.9.5, Windows 10 Via Bootcamp |
You are mistakingly thinking that the I/O on the C 24 will get its signal from ProTools without being connected to your HD I/O and that is not the case.
You seem to not be reading my posts or ignoring or not understanding them. Since Barry seems to have the free time available, I'd take him up on he offer for a call. |
#16
If my questions fall below the threshold of what's acceptable, let me know and I'll stop asking. |
#17
The manual which you can get online shows the DB25 Connections on the back of the C24.
And to be honest that manual can help you set up everything step-by-step. As far as cabling goes digidesign/avid used to sell a C 24 cable kit, about 400 or so dollars and it was the connections in between the HD I/O and the C 24
#18
The main misunderstanding you have is that the C24's I/O aren't "seen" by PT. They need to be fed by the ins/outs of the HD I/O. Have you read this document? It lays it all out. https://www.avid.com/~/media/avid/fi...uide_41362.pdf |
#19
-- I will need a DB25 to DB25 cable to connect the out of the HD IO to the "pro tools in" (I think) on the C24. -- I will need to somehow map a stereo out from the HD IO back into the C24. -- For each track I want on the cue, I will need to map their outputs to the stereo out I mapped on the HD IO. Not sure about this... -- Then feed channels 1 & 2 on the cue output, to the L&R inputs on the distribution box. Not sure, but likely would have to do something similar for control room monitors and live room monitors. Sent from my iPad using Tapatalk |
#20
Yes, and while it sounds expensive, it is actually a bargain. I spent almost a thousand when I ordered custom-made cables from proaudiola.com (but I was so happy about the quality of their work I didn't mind the price)
FS: HD 16x16 I/O Analog- EC | docric | Buy & Sell | 1 | 08-11-2016 01:10 PM |
HD I/O 16x16 Analog +1-2 | MarkH | Pro Tools HDX & HD Native Systems (Mac) | 2 | 01-20-2016 08:48 AM |
HD I/O 16X16 Analog W/Logic X? | triton92 | Pro Tools HDX & HD Native Systems (Mac) | 28 | 03-11-2015 10:20 PM |
HD I/O 16x16 Analog Revision A and B | SoundReplay | Pro Tools HDX & HD Native Systems (Mac) | 0 | 07-04-2014 05:52 AM |
HD I/O 16x16 Analog | maxx.monopoli | macOS | 5 | 02-17-2012 10:19 AM |
