Old 08-26-2003, 03:11 PM
voltech voltech is offline
Default Maxim / dither plugin on master fader?
I was wondering if someone could help. I want to bounce to disk a mix. I have a master fader set up and am using Maxim with 16 bit dithering enabled. Is it Ok if the meters on the master fader go into the red althe time?? Or should I drop the level here. - it sounds fine.
Thanks for the help!
Voltech
Old 08-26-2003, 03:26 PM
stoogee stoogee is offline
Default Re: Maxim / dither plugin on master fader?
Hello and welcome to the world of mastering.
I can't really say much as Im learning about this too.
But i've learnt from others here, that unless you are a pro mastering engineer who knows what hes doing, then don't let the faders hit the red.
Dont use maxim too much either, dont set the threshold too high, just enough to boost the output, and set the ceiling to -0.3db. That should sort you out for now.
Stu G
Old 08-26-2003, 03:54 PM
thanks for the help..
Old 08-26-2003, 09:46 PM
MidnightFlyer MidnightFlyer is offline
Voltech
Don't let the master fader go into the red. I use Maxim on every session, but I don't use the dither feature on it. Instead I use the digi dither, right after the Maxim. On the Maxim a good setting is 'threshold, -3, 'ceiling -.5 and .1 ms. I got these settings from a guy on the TDM forum. I like these settings. Before you drop you levels on the master fader, (which you want to keep at 0db) try dropping other levels on hot tracks. You don't want to record hot with digital. If you clip anywhere, go back and adjust.
Old 08-28-2003, 03:45 AM
Again.. Thanks for the help on Maxim
Voltech
Master Fader and First Plugin Question... M2E Pro Tools TDM Systems (Mac) 5 01-01-2011 02:32 PM
Maxim on the Master Fader MidnightFlyer Pro Tools TDM Systems (Mac) 3 06-05-2003 09:38 PM
Use of dither on Maxim - on Master Fader MidnightFlyer 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 01-11-2003 02:37 PM
Maxim on the Master Fader MidnightFlyer 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 12-23-2002 10:13 PM
What Mono/Phase plugin for Master fader? beatboy Pro Tools TDM Systems (Mac) 1 11-20-2002 08:45 PM
