Old 09-29-2015, 07:12 PM
Wall2Wall Wall2Wall is offline
Default Re: Bounce to disk not the same mix as record down???
Won't get a full cancel if you are using reverb, chorus and other modulation stuff.
Old 09-29-2015, 07:38 PM
emilano emilano is offline
no reverb or other funky fx like that in this simple mix...
Old 09-29-2015, 07:42 PM
A quandary. Did you try to import into a new session? Same outcome?
Old 09-30-2015, 08:56 AM
I also have been bit by the bus/output bug. I bounced mixes and the final 2-mix was actually missing several tracks. when I went digging, it turned out that some(the missing ones) had their output assigned to a Bus that had the exact same name as my usual main outputs. Now, every time I bring in a session from another studio/system, the first thing I do is open the IO settings>Bus tab and delete everything in italics. Then click on the right top OUTPUT column to bring all physical outputs up to the top so I can verify things are correct. 2 minutes of time there can prevent hours of hair pulling later
Old 10-01-2015, 10:58 PM
BobbyDazzler's Avatar
BobbyDazzler BobbyDazzler is offline
Do you have any noise reduction plugins with adaptive settings?
They can give serious variances.
HP Z2 Xeon 6 Core, Blackmagic Decklink HD Extreme 3D Win10, PT ver.. Latest
  #16
Old 10-02-2015, 03:03 PM
brianjanthony's Avatar
brianjanthony brianjanthony is offline
What albee and others have said.
I inherit more than half my work from other studios running Mboxes, 002s, 003s, etc. And sometimes the busses are even named the same. All kinds of issues on bounces. Most of the time, I end up manually rerouting all the tracks to a new master bus/fader etc to get rid of the problem.
I was bouncing songs this week that constantly lost the lead vocal till I re-routed. Drove me nuts.
Brian
www.brianjanthony.com
MacPro 6 core 3.46 Cheese Grater
HDX and HD NATIVE
48 gig Ram
PT 2019. Something
Sierra
192 IO and 96 IO
TDM user way back. PT user since 98.
I'm either working, sick, or both.
  #17
Old 02-10-2019, 11:54 AM
Tom Cangemi's Avatar
Tom Cangemi Tom Cangemi is offline
Hey Emilano,
I just noticed the same issue with upgrading to PT12. My mixes tht I clearly hear and understand do not match my bounces. Have you figured this out yet? TNX
  #18
Old 02-10-2019, 12:35 PM
Southsidemusic's Avatar
This thread is 4 years old. I would hope he figured it out already
Best Regards
Christopher
#thestruggleisreal
South Side Music Group
WEBHOME
  #19
Old 02-19-2019, 05:15 AM
yuyu yuyu is offline
modulated delays behave different
Bounce to Disk issues and bounce to direct show error. SeattleHank Windows 7 01-01-2014 12:41 PM
Bounce To Disk or Record To Track??? Audio quality... RWTV Tips & Tricks 12 10-23-2013 01:52 PM
Bounce to Disk intermittently causes freeze and disk unmount after PT 10.2 Upgrade AllThingsMusicStudio macOS 0 06-28-2012 07:16 PM
Record to disk vs bounce to disk Johncmuzic Pro Tools TDM Systems (Mac) 19 11-05-2006 09:42 PM
Bounce to Disk - Record on CD digimog Tips & Tricks 8 07-02-2004 08:03 PM
