Old 04-09-2019, 03:29 PM
senghor senghor is offline
Default Track fader and gain indicator
Hi!
How to set PT 2018 so that in a track the fader and volume indicator moves at the same time. I mean that the gain indicator and the fader show the same volume in a track.
Thank You.
Win11 Pro
Intel i7-12700K @3,6GHz, RAM 32GB
UAD Apollo and pre-amps, Pro Tools 2023
lots of plugins
Old 04-09-2019, 06:16 PM
Default Re: Track fader and gain indicator
Your question is not very clear, but I am guessing you are looking for the post fader meter setting under the Options menu.
If that is not it please ask again.
(You want to use on pre-fader on tracks you are recording to, so you can see the actual ADC input level.).
The Pro Tools Reference guide explains the metering options and meter types very well, and you should have a good mental picture of that and the whole track signal flow also well explained there.
Old 04-09-2019, 06:44 PM
Yes, I am searching post fader meter setting under the Options menu.
Win11 Pro
lots of plugins
Old 04-09-2019, 06:47 PM
john1192 john1192 is offline
you will find "Pre-Fader" as a selection in the Menu !!
Macmini M1 8/512 -OS 12.3.1 and PT2022.4
Logic Pro X 10.7.4
RME BabyFace Pro
Macbook Pro july 2014 2.5ghz 16gb ram 512gb SSD - OS11.6.5 - PT 2021.3
Logic Pro X 10.7.4
RME BabyFace Pro
Old 04-09-2019, 06:55 PM
Doh
10.3 and 10.3.1 Small Volume Fader AND Clip Gain Fader Problem Ale macOS 1 10-11-2012 10:07 AM
Basic Gain Structure Fader/Master Fader Question acmost Pro Tools TDM Systems (Mac) 1 05-16-2011 05:36 AM
Fader and Level Indicator Question. philip888 Tips & Tricks 9 11-03-2010 09:04 PM
change gain, but volume indicator doesn't move. hitwriter 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 03-28-2005 08:05 PM
change gain, but volume indicator doesn't move. hitwriter 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 03-28-2005 07:47 PM
