Waves 9 - no gui in PT10
I'm getting the old Grey Box Phenomenon on all Waves 9 plugs. They load, but no display. Specs:
PT 10.0.2 CPTK Win 7 64 bit i7 2600k 3.4ghz Asus Sabertooth p67 32gb RAM M Audio FTP Have tried running PT as Administrator (following a forum search of an old thread), but nada. VST versions of plugs working fine in other DAWs (Sonar, Cubase, Audition). Thanks for all help. |
Re: Waves 9 - no gui in PT10
I downloaded the Demo version of a couple of Waves pluggs like SSL. I do get the GUI, but when I add a couple of SSLs, save the session, close and re-load it: problems.
The volume fader in the plugin is at 100%, it makes noise without stating to play the session. Some times I can remove the plugin, save, close and re-load and I can play the session. I have tried to delete the prefs in both PT and Waves. Re-installed both. Using one plug works OK, but if I add several........ Win7 64bit ultimate. Waved V9 demo. My computer is working as it should and is Avid complient. |
Have you tried changing the "Regional and Language Options" in Windows? I'm still using Waves V8 here so it may not be the same, but for me this fixed all my issues: Quote:
/ Erik |
I'm running Waves 9 without any problems here on PT10, Win 7 64bit.
I'm in the Netherlands and had previously all kinds of troubles until I indeed changed the .(dot) and ,(comma) in my regional settings. Try it like Erik mentions, I'm pretty much convinced all your problems are solved. Quote:
i7 5820K @ 3.3Ghz, 32Gb, Windows 7 Ulimate 64, 1x M.2 512 SSD, 1x Spinpoint F1 1TB, 2x Spinpoint F3 1TB, ProjectMix IO, Axiom Pro61, PreSonus Monitor Station,SM ProAudio Stage Buddy, KRK VXT6, AKG K271, SE220A, PT 12.4.0, AMT IEP, Omnisphere, Trilian, EWQL CCC, EWQL Spaces, Ministry Of Rock, Gypsy, Fab Four, NI Komplete 9 Ultimate, NI Maschine, ProjectSAM Orchestral Essentials, Waves V9 Musician 1, Morphoder, CL4 |
All waves plugs working fine here!
Raoul Crane
www.blaze-studios.co.uk PT 10.3.10 HD Accel 6, Mac Pro 5.1 12 Core 3.46hz Dual Boot Lion 10.7.5 and Maverick 10.9.5 32GB Ram Magma PE6R4i Chassis |
I'e had this issue before and tracked it down to an update with my ATI video card. I rolled the drivers back and still had the issues. I finally resorted to wiping the hard drive and reinstalling Win 7 and the ATI driver. Worked fine after that. Pain in the rear though.
Might try turning off Windows User Acccount Control - need to reboot for it to take effect.
Wow, what a MESS. BSOD on attempted driver install. A solid hour of safe modes, system restores, installs, failed installs, uninstalls, reinstalls again, driver sweeps, endless restarts and finally I have an updated AMD driver. In the process, Pro Tools rolled back to 10.0.1 (probably there's other stuff missing too), so needed to then restore the 10.0.2 patch. Finally I have my system back, and all display drivers are up to date. And still no gui on Waves 9 in PT10. Any other ideas, anyone? EDIT - just to say that Waves tech support form appears to be down as well. On Chrome and IE8 submitting the form generates page errors. Brilliant. |
This looks promising. Tested it in my studio. Will do more research during this weekend. Looks like I might need to buy a couple of waves pluggs.
Thanks. |
PT10 & Waves Ilok problem | Mr. Kelly | RTAS & TDM Plug-ins | 6 | 05-27-2013 02:45 PM |
No Waves V9 in PT10 Trial | eveaudio | macOS | 3 | 06-10-2012 08:16 PM |
PT10 and waves 8r11 | Raggi | Pro Tools 10 | 4 | 01-31-2012 12:06 AM |
Waves JJP Vocal Plugin & PT10 | anackman | macOS | 6 | 01-15-2012 10:39 PM |
Waves Plugins not displaying in PT10 | Jake66Bluz | Windows | 9 | 12-31-2011 02:49 PM |
