Issue after opening and closing projects.
All is well until I start swapping between sessions. After I've opened around 3 sessions pro tools starts to hang and give me messages like insufficient memory to open plugins. The only way to sort this is to close Pro Tools and restart it. To me it's like Pro Tools is hanging on to the chip assign on the TDM cards. I've turned use DSP cashe off. Has anyone seen this before or know how to sort this. It's getting to be a real pain.
Thanks in advance Sent from my iPhone using Tapatalk
Raoul Crane
www.blaze-studios.co.uk PT 10.3.10 HD Accel 6, Mac Pro 5.1 12 Core 3.46hz Dual Boot Lion 10.7.5 and Maverick 10.9.5 32GB Ram Magma PE6R4i Chassis |
Re: Issue after opening and closing projects.
Are these sessions made with 11 or 12? Or are they all made with the same TDM system?
Sent from my iPhone using Tapatalk |
All made on ProTools HD 10 with a magma chassis with Windows 7
Raoul Crane
I would call up the Task Manager window and click the 2nd tab(the one that show how much RAM is used by each running process) and move it off to the side while you work. Each time you open a session, note the usage, and again when you close each session. I am thinking that RAM is not being freed up(not that I have a clue why or a solution). Maybe a bad stick of RAM?
Thanks Albee I'll give your suggestion a blast
Raoul Crane
Opening/Closing Hi-hats in Stylus RMX | Infinite Identity | Virtual Instruments | 0 | 11-29-2012 05:42 PM |
Region Bin - Quick Way Opening/Closing | tj_davies | Pro Tools TDM Systems (Mac) | 0 | 03-18-2010 06:29 AM |
PT 7 crashing when opening PT 6 projects??? | JenTraz | Pro Tools TDM Systems (Mac) | 3 | 01-22-2007 08:48 AM |
Opening v7.1 projects in LE v6.4? | floatingpoint_32bit | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 10-03-2006 11:47 AM |
PT5 closing when opening second Autotune | Anibal | Tips & Tricks | 0 | 01-01-2000 08:40 PM |
