Time stretch and Pitch Shift
What is the best plugin.. Rtas, audiosuite or tdm to use for Time stretch and Pitch Shift? Iv always used logics which sound the best and wondering what is the best for vocals ect to change Tempo without pitch or change pitch without tempo? thx..:)
Re: Time stretch and Pitch Shift
Serato Pitch & Time
thx..:)
I second that.
Though Digi's TCE tool isn't bad alot of the time as well... You can choose to have either function as your default TCE tool in prefs...
Subject51 Producer / Composer / Remixer |
Waves Soundshifter Audiosuite does a nice job as well. Though I must qualify that I typically do time shortening, rather than lengthening, and sound effects, not music.
I like Pitch n Time, but for mono tracks the Waves sounds better.
STeve
macmandigital.com |
Each program has strength and weaknesses, depending on the source material and what you are trying to achieve. I have tried P'n'T, but had better results with Waves on my work. Why not download the demos and try it for yourself?
Recording artist/Engineer/Producer Waves beta tester |
I wholeheartedly disagree with most of you guys, I recently downloaded a demo of pitch n' time 2.2 thinking that it would work out fine and used it on vocals doing very small time compression changes (far below 15%) and there was so much aliasing I thought I was living back in 1998 (with Protools 4.3), hey it's cool if you're looking for that effect but usually this type of aliasing comes from time expansion!!! The old version of Serato (on my Mix Plus) was much cleaner except for the fact that it would change the level of the output and sometimes distort. The functionality of the newer version seems to be better (with output control) but ultimately the result sucks. I used the digirack version of Time Compression and it was soooooo much cleaner, I was shocked at the difference and was very pleased that Digi stepped up on this audiosuite, even the output level was consistant. BTW, I'm was using the 002 in this case. I have'nt used the Waves version yet but it's gotta be far better than Serato. Do a comparison and take a closer listen to the the difference and you'll hear what I'm talking about...I'm glad I did'nt buy the Pitch n'Time cause personally I would've been pissed buying a product that has regressed so much...it's rather unfortunate really because I would expect Serato to put out a product that is at least as good as it's predecessor. The upside is that I only used the Time Compression function and not the Pitch function so there is hope in the pitch department...
Happy New Year y'all. RS |
Pitch n Time seems to work best with music, while digidesign's default Time Compression works better on vocals.
Warmest Regards, Brian |
BIG BUG: Wrong playlist calculations when using AS Pitch 'n Time or Avid Time Shift | Franco1967 | Pro Tools 11 | 1 | 01-25-2014 11:31 AM |
PT8 - Pitch 'n Time LE and Time Shift - very slow to operate | Richard901 | General Discussion | 3 | 12-30-2008 09:00 PM |
Time Shift: Why no pitch/time strap?! | EricWillhelm | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 8 | 09-17-2006 05:44 PM |
Digirack pitch/time shifter doesn't stretch on 5.3.2 002??? | cane | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 11-01-2002 03:25 PM |
*** Time Stretch/Squeeze & Pitch Change *** | Dan Clark | Tips & Tricks | 5 | 10-09-2002 04:17 PM |
