Go Back   Avid Pro Audio Community > Other Products > The Drum Room
Old 05-22-2014, 04:32 PM
mrgroovy mrgroovy is offline
Default Strike Add Instrument to Kit Issue
I have Bounce Rock loaded as a kit in Strike. In the Strike window, I dragged the Claps sample from the kits on the left and placed it into the Strike Mix Window. I see it and when I click my mouse on it - I hear the claps. It does not however react to my controller when I try to find it on a key. Nor does it exist in the "Blue" single note keys in the strike window. Problem is I cannot record it if I am in record mode even if I click it with my mouse. Not sure if I need to assign it somewhere. I am not midi friendly unfortunately. Any help?
EDIT!!! Sorry Guys - Pg 21-22 of the manual.
2020 Mac Mini I7 3.2GHz, 36 GB Ram, Catalina, ProTools 2018.12.0 UAudio X6, Axiom Pro S49 MkII, Maschine MKIII.
PT 9.0.6 Start/Stop Issue and Plug-in Instrument Issue ZDF macOS 0 01-14-2013 02:47 PM
Strike isn't showing up in instrument list? Joe Porto Virtual Instruments 1 02-10-2012 07:28 PM
Strike: finding an instrument The Miff Virtual Instruments 1 04-27-2009 12:04 PM
Strike! doesn't show up in instrument trk. kevjones810 Tips & Tricks 3 02-26-2009 06:28 AM
Strike Instrument Edit? Jeff E Virtual Instruments 7 10-01-2008 04:44 PM
