Command 8 Fader Issue
Hi all,
When initialising, the first fader on my command 8 jumps up and down much faster than the rest and during a session, when the associated software fader is set at 0dB the hardware fader is at +12dB, and when i set the hardware fader all the way up at +12 the associated software fader is only at +2.2dB. If I push the software fader up to +12 the hardware fader clicks constantly. When I run the fader calibration test it behaves the same as when initialising and finishes at 0 with the rest of the faders but no change when out of utility mode. When performing the fader test it behaves the same again but when all the faders are at the top up the run (+12dB) it reads 820 rather than 1023 like the rest I'm in the middle of a mixing session so I'd really like to get this problem sorted as soon as possible, so if anyone can help I'd be very grateful.
MacBook Pro 17" 2.33 GHz 2GB RAM 100GB 7200 RPM Internal Drive Glyph GT 050Q 320 GB FW800 External Drive OSX 10.5.8 PT 8.0.1cs1 002R Command 8 |
Re: Command 8 Fader Issue
Sounds kinda like my problem, but my faders were held down for a while during boot. So I believe I (and you) may need new faders?
good luck, RStauss |
How do I get a new one? George Ware |
I've had similar problem couple of days ago - fader 4 - I've updated firmware to the same version no help, of course. then I plugged it in another wall outlet 'cause i've realized I have grounding problem. And now, I'm happy mixer again.
AVID HD Native PCIe + HD OMNI; Digidesign 192 I/O (2x) & 96 I/O; Icon QCON Pro & QCON EX; Softube Console 1; NI Kontrol 25; Arturia SparkLE; UAD-2 Satellite DUO; UAD-2 PCIe DUO; Tascam DA-3000; TK Audio BC1-S; Warm Audio WA76; SSL XLogic Alpha Channel (x2); SSL X-PATCH; Lindell Audio 6X-500, 7X-500 & PEX-500 (all x2), lots of TCE & Lexicon reverbs; VintageMaker LittleOne 16/2 Summing Mixer; MUTEC MC3+ SmartClock; Mac Pro (2009) 8 Core 2.26; 24 Gb RAM; Pro Tools HD 12.8 |
Administrator, delete 94hunter from user list. it's a damn spam bot !!!
Just reported to DUC admin
If you guys need faders I have 15 spares. All brand new!
Have them for my control 24, but they are the same fader. (My Control 24 already has all brand new faders installed.) 15 for $400, just under $27 each.... brand new. (I'd want to add 3% for paypal, and shipping would be dirt cheap. They're light) That would serve almost 2 of you for all brand new ones and you'd have working spares! Bulk buy! Bulk buy! Don't delete me! I'm not a bot! heh heh, or am I? Sent from the future to destroy Digi's fader sale profitability! heh heheheh! MWAH HA HA HA HAAAAAAAAAA [email protected]
Shorty: Table Syrup Records Mac Pro 5,1 3.33 GHz Hex, 32GB EFI Flashed - 5 GT/s Modded 7950, Dual Apple 23" OSX Sierra Pro Tools HD 11.2.2 Waves IOS, IOX, STG2412 Extreme Server (x2) Logic Pro X, DSP Quattro, Final Cut Pro X Waves Mercury+SSL+AbbeyRoads Trident S65 with embedded US-2400 Live: 2012 Mac Mini, Dual SSD, i7 2.4, 16GB Win 10, OSX Sierra LV1, MRSG Hardware from above (same gear) Dual Dell P2418HT Touch Screens Waves Icon X (x2), M, with Screens Custom enclosure |
BTW: I do keep a dust cover whenever it's not in use. George Ware |
Better than compressed air: Deoxit
Get some Deoxit, use D5 and G5 Gold Used to be Cal Lube, now it's all Deoxit. Works fantastic. D5 first, then Gold to protect. Or better yet if you can find F5 that's specifically made for faders, though the only time I used their fader stuff it was F100 which is 100% of just one of the chemicals. They also make Fader Grease, I haven't used it but heard really good things. It comes in a tin about the size of tinning flux would come it, and you brush apply it, it's kind of a paste. I'd think it would work in motorized faders just fine if you used it sparingly, but if there is too much left behind it would collect dust. Also, I don't know if you can apply Gold after it, I would think that would just rinse it away (Kind of like spraying WD40 on wheel bearings)
D-Command ES + Fader Madule Fader Problems | FedericoF | ICON & C|24 | 11 | 05-24-2013 04:27 PM |
FS 24 Fader D Command | puffin | Buy & Sell | 0 | 06-14-2012 07:55 AM |
FAder Issue D-Command | kd_special | ICON & C|24 | 9 | 07-10-2010 10:30 AM |
40 fader D-Command! | RichN | ICON & C|24 | 8 | 10-22-2008 04:50 PM |
'Fader Pack' and ProControl Fader order issue | Ciaran | ProControl, Control|24, Command|8 | 2 | 03-21-2005 11:58 PM |
