"STEREO" Mono Pair
Yesterday a received a dialog (10 Ch) to edit,clean up.
That's a PAIR of MONO TRACK. Can I use just ONE channel, because they are MONO. Some advice will be good. Thanks Funk Dias
www.myspace.com/aureliodias |
Re: "STEREO" Mono Pair
Mono is mono, whether its on one track or twenty. Try this, take your two "mono" tracks, play them through the same monitor path but flip the phase on one od the tracks. If you can balance the gain between the two tracks so that the sound output cancels (to silence) then you do truly have mono on both tracks, and it is safe to make the second mono track inactive and hide it. I wouldn't throw it away just in case you discover a problem with the first track.
Call me by my real name, "Postman" |
Thanks Richard.
Consolidate vs Duplicate - "Stereo" vs. Dual Mono Behaviour | rnd | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 06-05-2013 01:03 AM |
What are the difference between using a "mono" vs "mono/stereo" plug in on mono track | rockguitarist1255 | Pro Tools 10 | 4 | 12-07-2012 08:07 AM |
Mono, but no "Beatle Stereo" | Moses Presley | Tips & Tricks | 18 | 09-22-2003 02:51 PM |
HOW can you import a "stereo" WAV. file into PT as a "mono" file? | peter parker | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 11-21-2002 09:14 PM |
What do i import a "dual mono" audio file as??? mono or split stereo? | peter parker | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 8 | 07-17-2002 04:02 AM |
