#21
Re: is 370 mb/sec enough? SSDs with Blackmagic multidock
#22
The only reason I brought up USB2 is that for most cases, the bandwidth capabilities of SSD isn't required by someone only recording 24-ish tracks at home. Geesh!
Eric Seaberg • San Diego, CA A.E.S., I.E.E.E., S.M.P.T.E., S.P.A.R.S. |
#23
We supply USB 2, USB 3, USB 3.1 (and not the Mac Gen 1 BS), and USB C type on our systems. Many Win system devs do. You are stuck thinking in the Mac paradigm. Considering most PC middle of the road systems are faster than any Mac on the market, I would say they are more than fit.
pro-tools-pc.com TRASHER Pro Tools Utility(updated 4-11-2024) HD Native, Avid 16x16, Eleven Rack, Focusrite Clarett 8preX, UA Quad Apollo TB. Intel I7 9900k Win 10 |
#24
Better to have a system that's over-spec'ed than to have one that could end up straining. People tend to underestimate what they're going to do with a system and end up wishing they had spent the money more wisely in the beginning. That's why I wish I had ssd's for my sample drives - the 7200 rpm spinners I have are major league slowing down my work. It's only been recently that ssd's big enough to house my libraries are available along with something like the Blackmagic MultiDock to make efficient use of them. And one can hot swap drives as one wants to. Not to mention an ssd is way more rugged than a spinner. |
#25
#26
#27
#28
To address the point you are trying to make, It took me aprox. 5 seconds on both Amazon and Newegg to find USB 2 exernal drives and even more available drive enclosures. Now, to Eric's point, it is 100% possible to record to a USB 2 drive as he states. USB 2 has 480Mbp/s transfer rates. 48K/24bit audio is 288Kbp/s per track. Lots of us did it all the time. The issue with USB 2 recording was typically a problem due to heavy Southbridge activity and hub conflicts. A laptop with only 1-2 USB hubs with a lot of peripherals hanging off of them will get worse USB drive performance than a well maintained desktop with 4-5 USB hubs and no devices sharing the hub with the drive. Wireless for instance is horrific to system performance and DPC latency. It would create a mess on the Southbridge. It is just less of a problem now because we have the power and speed to push through it most of the time. This is the same problem with Thunderbolt chaining. The end devices have far less bandwidth to work with and why hard drives will get far less write/read performance at the end of a chain when monitors are hogging the bandwidth. Would I recommend USB 2.0 today?? no, there is far better options. But the point still stands, it was and is completely viable as a record drive option.
#29
What about either the OWC or the Akitio 4 bay Thunderbolt 2 boxes. The Akitio shows that it gets full drive speed out of the SSDs - not sure about the OWC.
I have owned the MultiDock since it came out and it is rock solid. But mine is TB1, V1 with only one TB port. As I transition to the new iMac I am very limited in TB ports and could dearly use the daisychain port. I could always buy the MD V2 but how about these other two alternatives? 1/2 the price and considerably faster at least. As a last alternative there is a new TB3 4 drive box from Akitio as well.
2017 27" iMac 3.8GHz i5, 1TB SSD Logic ProX, Studio One V4, PT current version, Apogee Ensemble TB Musician: http://www.ivanlee.net/ Design Engineer: http://www.propowerinc.com/resume.html Last edited by propower; 07-21-2017 at 02:35 PM. |
#30
Two SSDs In Mac Mini | GTBannah | Pro Tools 11 | 11 | 09-14-2016 07:38 PM |
About SSDs in DAWs | Sir Les 2 | General Discussion | 27 | 01-18-2014 11:13 AM |
Blackmagic Design MultiDock | John_Toolbox | Storage Subsystems | 0 | 08-26-2013 08:43 AM |
SSDs | Sweepxcore | Pro Tools 10 | 4 | 10-20-2012 01:13 PM |
forget SSDs | Craig F | Storage Subsystems | 7 | 04-18-2011 06:31 AM |
