Old 06-05-2012, 05:30 PM
Ryan Young's Avatar
Ryan Young Ryan Young is offline
Default Export Clips as Files... (to mono)
I have a session with production audio files that are 4 channels. I have them set up on LCRS tracks within Pro Tools for easy editing. Is there a way to "batch" export these files as a mono (summed) file? Not by bouncing them all down individually. This would help for the picture editor and will then help me with conforms.
Session Edit Window
-Ryan Young
•Pro Tools 12.6 (x2)
•OSX 10.11 & 10.12
•Mac Pro 2 x 2.66 GHz 6-Core Intel Xeon (x2)
•16 GB 1333 MHz DDR3 (x2)
•HD Native PCIe (x2)
•HD Omni (x2)
•192 i/o
•96 i/o
•4 Seagate Barracuda 1.5TB 7200 RPM 32MB Cache SATA 3.0Gb/s 3.5" Internal Hard Drive
•Blackmagic Intensity Pro (HDMI)
Old 06-05-2012, 05:46 PM
KMcK KMcK is offline
Default Re: Export Clips as Files... (to mono)
Split the tracks to mono and then export an AAF would be my first rec.
Or if you don't care about keeping your edits in tact for the picture guy, consolidate all the tracks, and you'll have nice long individual mono files in your Audio Files folder ready to copy over.
Old 06-05-2012, 05:56 PM
Ryan Young's Avatar
Thanks for the tip, KMcK. Unfortunately, the editor is working in FCP and can't import an AAF. My PT session is full of entire audio files so there are no edits to preserve. I'm trying to give the picture editor a summed mono export of the 4 channel tracks (of individual lavs) to make it easier for him to edit with. I'm trying to avoid having him edit with multichannel files and just one mono sum. Anything else? :/
-Ryan Young
•OSX 10.11 & 10.12
•HD Omni (x2)
•192 i/o
•96 i/o
Old 06-06-2012, 12:07 AM
Oh I misunderstood. You essentially want to mix the 4 tracks into one mono track for the editor, right?
Pro tools doesn't have any way of mixing faster than real time. You can split the tracks to monos and assign them all the same mono output and either bounce to disk or record back onto a mono track in the session via a bus, but you can't mix tracks via an export, only in real time.
Old 06-06-2012, 12:41 AM
Ryan Young's Avatar
Thought so... dang :) Thanks for the tips anyways!
-Ryan Young
•OSX 10.11 & 10.12
•HD Omni (x2)
•192 i/o
•96 i/o
Title/Name confusion with "export clips as files" stargazer macOS 0 03-02-2014 11:05 PM
Pro Tools 10 crashes on Export Clips As Files. yamahadrums macOS 3 12-27-2012 11:51 AM
Clip Gain and Export Clips as files Farmer Dave macOS 2 03-18-2012 10:48 AM
Need an app that will export mono SDII files mondoJML Pro Tools TDM Systems (Mac) 4 09-18-2003 04:33 PM
Need an app that will export mono SDII files mondoJML 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 09-18-2003 03:25 PM
