Old 11-06-2011, 05:22 PM
OnABudget OnABudget is offline
Thumbs down Playback = Slow & Distorted.
With Windows XP 32-bit (my previous OS) & Windows 7 64-bit (my current OS):
*I use an Mbox 2 Usb with Pro Tools LE 8.0.5.
*I get a slow & distorted playback in and outside of Pro Tools LE 8.0.5. This started happening 4 days ago.
*In PT8.0.5, when I hit the 'play' button, the 'play' icon flashes about 4 times; as if I selected a pre-roll. I didn't.
*Deleted all Digidesign/Avid-related products and executed a fresh install a gazillion times with both operating systems, checked my preferences, optimizations, setup options, double-checked the health of my hard drives, tried different usb slots, etc. No dice. Same issue.
*Now with my device plugged-in, after a restart, my keyboard and mouse are disabled at the Windows login screen.
*My option to select 48hz is never saved. It always resets to 44hz. Weird.
*Other than having to invest in a new non-Avid audio interface, with a very tight budget, how can this be remedied?
Thank you advance.
SiSoftware Sandra
Processor
Model : Intel(R) Core(TM) i5-2500K CPU @ 3.30GHz
Speed : 3.59GHz
Cores per Processor : 4 Unit(s)
Type : Quad-Core
Integrated Data Cache : 2x 32kB, Synchronous, Write-Thru, 8-way, 64 byte line size, 2 threads sharing
L2 Cache : 2x 256kB, ECC, Synchronous, ATC, 8-way, 64 byte line size, 2 threads sharing
L3 Cache : 6MB, ECC, Synchronous, ATC, 12-way, Exclusive, 64 byte line size, 16 threads sharing
Computer
Mainboard : ASRock Z68 Pro3-M
BIOS : AMI (OEM) P1.60 10/25/2011
Bus(es) : X-Bus PCI PCIe USB i2c/SMBus
Multi-Processor (MP) Support : No
Multi-Processor Advanced PIC (APIC) : No
Total Memory : 8GB DIMM DDR3
Chipset
Model : ASRock Core (Sandy Bridge) DRAM Controller
Front Side Bus Speed : 100MHz
Channels : 2
Memory Bus Speed : 2x 667MHz (1.33GHz)
Memory Module(s)
Memory Module : 2GB DIMM DDR3 PC3-10700U DDR3-1334 (9-9-9-25 4-34-10-5)
Video System
Video Adapter : ATI Radeon HD 5450 (80 SM5.0 650MHz, 512MB DDR3 1.2GHz 64-bit, PCIe 2.00 x16)
Graphics Processor
Compute Shader Processor : ATI Radeon HD 5450 (80SP 650MHz, 512MB DDR3 1.2GHz 64-bit)
STREAM GP Processor : ATI Radeon HD 5450 (80SP 2C 650MHz, 512MB DDR3 1.2GHz 64-bit)
Storage Devices
Seagate ST31000528AS (1TB, SATA300, 3.5", 7200rpm) : 932GB (D:)
SAMSUNG HD103SJ (1TB, SATA300, 3.5", 7200rpm, 32MB Cache) : 932GB (J:) (K:)
Seagate ST3320620AS (320.1GB, SATA300, 3.5", 16MB Cache) : 298GB (C:)
TSSTcorp DVD+/-RW TS-H653A (SATA150, DVD+-RW, CD-RW, 2MB Cache) : N/A (G:)
Logical Storage Devices
1TB_A (D:) : 932GB (NTFS) @ Seagate ST31000528AS (1TB, SATA300, 3.5", 7200rpm)
Audio_One (J:) : 488GB (NTFS) @ SAMSUNG HD103SJ (1TB, SATA300, 3.5", 7200rpm, 32MB Cache)
System Reserved : 100MB (NTFS)
Audio_Two (K:) : 443GB (NTFS) @ SAMSUNG HD103SJ (1TB, SATA300, 3.5", 7200rpm, 32MB Cache)
Hard Disk (C:) : 298GB (NTFS) @ Seagate ST3320620AS (320.1GB, SATA300, 3.5", 16MB Cache)
Optical Drive (G:) : N/A @ TSSTcorp DVD+/-RW TS-H653A (SATA150, DVD+-RW, CD-RW, 2MB Cache)
Peripherals
LPC Hub Controller 1 : ASRock Cougar Point LPC Controller
LPC Legacy Controller 1 : T0 C3-33
Audio Device : MSI Manhattan HDMI Audio [Mobility Radeon HD 5000 Series]
Audio Codec : ATI (AMD) HDMI Audio
Serial Port(s) : 1
Disk Controller : ASRock Cougar Point 4 port SATA IDE Controller
Disk Controller : ASRock Cougar Point 2 port SATA IDE Controller
USB Controller 1 : ASRock Cougar Point USB Enhanced Host Controller #2
USB Controller 2 : ASRock Cougar Point USB Enhanced Host Controller #1
USB Controller 3 : ASRock Etron USB 3.0 Extensible Host Controller
SMBus/i2c Controller 1 : Intel ICH SMBus
Network Services
Wireless Adapter : D-Link AirPlus G DWL-G510 Wireless PCI Adapter(rev.B) (802.11g (ERP), TKIP, 54Mbps)
Operating System
Windows System : Microsoft Windows 7 Home 6.01.7601 (Service Pack 1)
Platform Compliance : x64
Windows Experience Index
Current System : 4.4
(Isn't my Mbox 2 Usb device supposed to show in this report? I disabled the onboard audio via bios, but, it shows up here as ATI?)
PT 9 playback distorted, aliased and slow yeluhz_strongs Windows 4 07-03-2016 02:16 PM
003 & HP DV7 laptop = Slow distorted audio sharpo07 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 15 11-22-2013 03:56 PM
PT 9 is playback distorted, aliased and slow tsguitar1 Windows 4 06-15-2011 07:45 AM
Distorted playback skwad Windows 7 04-01-2011 08:58 AM
Distorted playback Sherry Q 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 04-11-2003 12:21 AM
