Old 01-04-2008, 11:50 PM
calicobumps calicobumps is offline
Default Pro Tools won\'t start up?
(I searched for a thread and can't find it - apologies if I've missed one.)
Computer model and processor speed - Mac ibook 2GHz Intel Core 2 Duo
OS version: OS X 10.49
Pro Tools version: 7.3.1
Amount of RAM installed: 2GB 667MHz DDR2 SDRAM
Any attached peripherals (hard drives, video devices, other firewire or USB devices that may be attached, etc): mbox 1
Number and type (firewire, SATA, SCSI, etc) of drives installed: no external drives used for Pro Tools
I've tried to follow the troubleshooting, haven't had any breakthroughs.
I've been using Pro Tools without any problems 'til recently, but I went to switch it on today and no luck.
I keep clicking on the PT logo in the dock, it bounces for a moment and then settles down without opening. Any ideas why not?
Old 01-05-2008, 03:14 AM
Phil Ogden Phil Ogden is offline
Default Re: Pro Tools won\'t start up?
What measures specifically have you tried so far? Have you run the Prebinding script?
http://www.myspace.com/philogg
Old 07-26-2010, 01:41 AM
Jaymzemicah Jaymzemicah is offline
Default Re: Pro Tools won't start up?
Just installed Pt 8, installation went fine. When I run it for the 1st time, it goes the loading plun in phase, and hags up on "structure.dpm", I've unstalled and reinstalled it 3 times, same problem!
Jaymze
Old 07-26-2010, 10:28 AM
Park Seward's Avatar
Park Seward Park Seward is offline
So what changed? Did you add/delete anything? Change any cables?
Are you using an 002 rack?
Park
The Transfer Lab at Video Park
Analog tape to Pro Tools transfers, 1/4"-2"
http://www.videopark.com
MacPro 6 core 3.33 GHz, OS 10.12.1, 8 GB RAM, PT12.6.1, Focusrite Saffire Pro 40, PreSonus DigiMax, MC Control V3.5, dual displays,
Neumann U-47, Tab V76 mic pre, RCA 44BX and 77DX, MacBook Pro 9,1, 2.3 Mhz, i7, CBS Labs Audimax and Volumax.
Ampex 440B half-track and four-track, 351 tube full-track mono, MM-1100 16-track.
Lion Pro Tools SE won't start on one account, but start on another AndrewGalas Pro Tools SE and Essential (Mac) 2 12-15-2011 12:06 PM
Pro Tools 9 NO START! 45parallelostudio macOS 2 11-08-2011 06:31 AM
Pro Tools will not start up. Help khenninger 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 11-12-2007 04:51 PM
Pro Tools won't start on my Mac Ralph Baumgardner 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 04-11-2007 03:24 PM
Pro Tools 5.1 Session Start—Record Start Interval Avid Pro Tools TDM Systems (Mac) 4 04-18-2001 09:27 AM
