Old 05-10-2005, 04:18 PM
dubman dubman is offline
Default midi and tempo change pt III
Givin this one another lash,. Hope theres an answer out there.
dubman.
Dose anyone know if you can change the tempo of a track without changing the tempo of a midi track. I'v got a midi loop that I want to match the tempo to.I can do it well enuogh with audio loops but the midi track seems to change no matter what I do.
Big D.
Only way (if I understand you)is to record the MIDI loop as Audio, say 2 or 4 bars. Once in audio use the time compression/expansion tool to adjust, Or alternatively, find out what tempo you want the loop to be and record it independently at that tempo.
I'm a bit confused as if it's a MIDI loop you should be able to make it any tempo you want.
Maybe let us know exactly what the 2 elements are that you are trying to lock.
Hope that helps.
Best,
Big D
Dubman.
Yeah I'v got a loop of midi goin, (not audio) and I want to set the song tempo to that of the loop. I can do it easy enough in cubaseSX but I'd like to do it in PT's LE.
so yeah, still looking for an answer on this one. I suspect there isnt , but there must be some kind of 'work around' to get it done ?
cheers
Dubman.
You should be able to set your MIDI tracks up in PT at the correct tempo, then import your audio tracks & use the TC/E tool in grid mode to stretch them to fit. You will get artifacts if you stretch too far. Using Ableton Live might work better?
Scott.
dubman
yeah i'm not sure you guys are gettin what I'm tryin to do.What I did was record some midi bass line and the trimmed it into a 1 bar loop. I didnt use a click so it dosnt match the tempo grid.I want to match the grid and tempo to the midi loop without changing the tempo of the midi loop.
spkguitar
Select the loop so that it loops properly when played in loop mode and then identify beat (ctrl+i).
dubman
tryed that, it works on audio but not midi. the midi loop still expands and contracts as you change tempo, so you cant match it up to the tempo grid
Lock midi so it doesn't change tempo? davey boy macOS 2 09-04-2012 07:08 AM
Want to change tempo AFTER midi was tracked pqlior@mac.com macOS 1 05-10-2012 03:42 AM
Tempo change causing midi volume to change plugin output tgrfox 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 08-05-2011 02:08 PM
Need to Change tempo but without changing existing midi data tempo? Einsteinwannabe Pro Tools M-Powered (Mac) 2 09-18-2010 07:58 AM
Midi Tempo Change ape77 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 07-03-2006 07:33 PM
