Old 11-24-2019, 11:07 AM
Bob Brown's Avatar
Bob Brown Bob Brown is offline
Evergreen Audio Design Group
Default Multiple inputs assigned to a track?
Is it possible to assign multiple inputs to a track (audio or aux)?
For example, you can assign multiple outputs of a track using control-click on the output. You see a little "+" sign indicating the output is assigned to say "Bus 1" and "Bus 16".
I would like to be able to do the same for inputs.
I know I can route different signals to different buses via an Aux track and route the output of each Aux track to the same Bus, then route that Bus to a track (basically summing all of the signals to mono).
Thanks,
Bob
Old 11-24-2019, 11:15 AM
BScout BScout is offline
Default Re: Multiple inputs assigned to a track?
No. Because that is summing as you've figured out. And summing = mixer.
(Whereas sending to multiple outs is just routing; just like in the real world on a console)
Old 11-24-2019, 04:30 PM
JFreak JFreak is online now
Everything becomes much simpler after you think about it for a second
Old 11-24-2019, 05:17 PM
Ben Jenssen's Avatar
I did think for a few seconds, and I thought; I could of course make a aux for every input and then route everything multiple places, recording trax with multiple inputs, so this could be programmed to happen behind the scenes, no?
Old 11-24-2019, 05:49 PM
Remember, this is Pro Tools we are talking about. If you cannot do it with S6 you cannot do it in software.
It is so fundamental that you have multiple inputs then mixer then one or more outputs. Why complicate things too much?
Of course in the analog world you can create y-cable to sum two mono signals together and have it on single console track, but PT session might have funny combination of greater than stereo tracks and this proposed "pseudo summing" should work everywhere if it was implemented.
I bet it is never going to happen. Not gonna eat a hat if it does, but I'm just shaking my head here... where's the facepalm emoji?
Old 11-24-2019, 05:59 PM
Not trying to complicate. Just pointing out, playing with, the thoretical idea of this particular question. I don''t know why you woud need the function.
Old 11-24-2019, 06:34 PM
Well I kind of do, but in analog domain and where there are not enough available channels for what I need to do. It hasn't been one or two times I have needed to solder a y-cable to mono-sum two signals together. Just that it is much simpler than what OP is suggesting.
In digital domain, no, never. Would not even think of doing that.
Old 11-24-2019, 06:46 PM
Well, that's that, then.
(Mmm, tape, cables, smell of soldering, sweat. )
Old 11-24-2019, 07:38 PM
cwsand's Avatar
cwsand cwsand is offline
Exactly.
Help Us Help You
Chris
Pro Tools 2024.3
Focusrite LS56
Focusrite Pro40 (3)
Slate Digital VRS8
Analogue Tonebuss 24 Channel
UAD-2 OCTO Core Accelerator
UAD Volt 2
macOS 10.15.7
32 GB DDR4 RAM
NVIDIA GeForce GT 740 2 GB
Old 09-11-2023, 05:44 AM
bad jitter bad jitter is offline
I could use this functionality, and it would be very handy for certain workflows.
Soloing one track and an AUX with multiple pre-fader inputs HaendelGabriel Pro Tools | Intro Discussion 0 09-20-2017 07:06 AM
Multiple Playback Channels Without Being Assigned networker Pro Tools HDX & HD Native Systems (Mac) 1 03-06-2017 01:49 PM
Pro Tools 11.2.1 doesn't display inputs already assigned Pan Pot Studio Pro Tools 11 0 10-25-2014 01:20 AM
Multiple Outputs in i/o assigned to A 1-2 KingFish Pro Tools TDM Systems (Mac) 6 05-13-2009 05:47 PM
> HD - Audio leak thru track w/ no voice assigned Howardk Pro Tools TDM Systems (Mac) 0 02-22-2006 03:00 PM
