Old 11-13-2019, 10:23 PM
Boe Larsen Boe Larsen is offline
Default PT crash after bounce
Hi DUC
It's been a while...
Did a clean install to OS 10.13.6 and installed PT Ultimate 2019.6.0.
Now, often PT crashes after a bounce. The bounce is done correctly though.
Also I get the spinning wheel every once in a while and I seem to register that the app is more sensetive to other apps running in the background.
Any ideas?
Boe
Boe Larsen
Producer
www.millfactory.dk
Old 11-14-2019, 11:23 PM
cwsand's Avatar
cwsand cwsand is online now
Default Re: PT crash after bounce
My first guess would be a plugin issue - you might try some test bounces with all instances of a particular plugin deactivated to see if it still crashes after bouncing. Of course, if it happens with no plugins in the session then it's probably something else causing it.
Help Us Help You
Chris
Focusrite Liquid Saffire 56
TCE Studio Konnekt 48
PreSonus Digimax LT
Pro Tools HD 2019.10
Old 11-14-2019, 11:55 PM
Ok, will try that, thanks.
Boe Larsen
Producer
www.millfactory.dk
12.8.1 crash during bounce jchan Pro Tools 12 29 10-16-2017 05:02 PM
Offline bounce crash, probably Waves-related, and offline bounce not 100% correct Skwaidu Pro Tools HDX & HD Native Systems (Mac) 3 03-23-2015 04:55 PM
Crash at Bounce mickeyrouse Windows 1 12-05-2014 01:54 PM
Bounce to Mp3 crash j.thomas Pro Tools 10 1 11-14-2011 09:49 AM
10.5.7 Crash On Bounce andyj4308 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 05-28-2009 01:33 PM
