Old 05-09-2019, 11:10 AM
EddieJones's Avatar
Default New Software Release EuControl Version 19.5.1
UPDATE:
v19.5.1 is out with 15 bug fixes. Whats New in 19.5.1
Avid is pleased to announce the release of EuControl/Workstation software version 19.5 for the S3, Dock, Pro Tools|Control, and Artist Series. Log in to your Avid Account (for S3, Dock, and Pro Tools | Control) or My Artist portal to download the new software.
  • S6 style Monitoring Control for the iPad Control App and Dock
    Control any EUCON Monitoring App - MTRX, XMON, Pro Tools Master Fader, Nuendo and Pyramix
  • Scroll to Track and Scroll Into View banks Controllers
  • New Attention methods from Pro Tools (replaces Attention on Select)
  • Options to Attention from clicking on different areas of PT (Track Name, Fader, Plugin, Pan, Send, Edit Window etc.)
  • Option to display the function/knobs from what was clicked on in Pro Tools
  • Option to then open that Functions Window in Pro Tools.
  • Pan and Send Windows now open in addition to Plugin Windows when selected from the Surface
  • Option to open these Windows from function button press or knob touch
  • Improved Momentary Fader Value options, added fall back to name whilst touching
  • New Pro Tools Softkey – Insertion Follow Playback
EUCON 19.5 on Avids Blog
Old 06-10-2019, 12:02 AM
[email protected] info@giampaolotestoni.com is offline
Default Re: New Software Release EuControl Version 19.5.1
This updates are full of bugs, I had to reinstall version 19.5.0.Using logic Pro X but also Dp 9, Artist Transsport does not display the info on the led, the Artists Mix locks when the apps are closed. A real disaster. Can you please check? Thank you.
Old 06-10-2019, 01:15 AM
streamingtheatre streamingtheatre is offline
Same issue for me here. My transport unit stops from time to time. I have to turn it off and on again to continue working.
Old 06-10-2019, 02:13 PM
EddieJones's Avatar
We know of an issue with the Transport display if on Sierra, can you please confirm. (If this is correct any reason not to update to High Sierra ?)
Other than that I'm not hearing of it being full of bugs so please list them out so I can address them.
Old 06-10-2019, 11:35 PM
Thank you Eddie, yes, Im on Sierra with this machine. It`s not really supported by high sierra, so it`s a little bit tricky.
Old 06-12-2019, 05:16 PM
sjcollins92 sjcollins92 is offline
Eucontrol keeps crashing if adding a aux or a new track, i have 4 artist mix, protools dock and XMON connected to a PC, i keep having to keep starting eucontrol again.................. I have protools 2019.5 and eucontrol 2019.5.1
Old 06-12-2019, 05:19 PM
EddieJones's Avatar
Please redownload the installer making sure its build 44 and update.
Old 06-12-2019, 05:38 PM
Thanks Eddie It works............
Old 06-17-2019, 11:49 PM
made made is offline
same thing here. Eucon 19.5.1.44 MacOS10.12.6
OLED stops working once using a wheel command.
Using a Custom wheel command is crashing ProTools
Mac Studio, 32GB, PTHD2022.7, OS 12.5.1, S3, Transport, (EuCon 2022.4.0.78)
LIO-8
BlackmagicDesign UltraMonitor3G
Reaper 6.66, Fireface UCX
MacbookPro M1Pro PTHD2021.12 MacOS12.1
MOTU 24Ao AppleTB3toTB2->AppleTB2->Ethernet->AVB
Old 06-18-2019, 01:16 PM
EddieJones's Avatar
This is a OSX Sierra issue (OLED) we are looking into a workaround but Apple changed code. I think the Crash has been fixed in PT 19.5
New Software Release EuControl Version 19.5.1 EddieJones Avid S1, S3, Dock and Control App 19 06-05-2019 09:59 AM
New Software Release EuControl Version 19.5.1 EddieJones Avid S1, S3, Dock and Control App 1 05-09-2019 01:45 PM
New Software Release EuControl Version 18.3 EddieJones Avid S1, S3, Dock and Control App 7 04-19-2019 12:57 PM
New Software Release EuControl Version 18.3 EddieJones Artist Series 26 04-05-2019 01:10 PM
New Software Release EuControl Version 18.3 EddieJones Avid S1, S3, Dock and Control App 12 11-10-2018 02:43 PM
