Old 03-07-2018, 01:23 PM
PT user PT user is offline
Default Sync HD and Dante?.....
Just looking for advice. If I ditch my Avid interfaces a go down the Dante route into a Monitor controller do I loose the use of the Sync HD?.....I clock to video ref and use word clock out of the Sync HD for the Monitor Controller. Any advice would be appreciated?
Old 03-08-2018, 01:03 PM
Default Re: Sync HD and Dante?.....
If you're talking about using Dante Virtual Soundcard, then that becomes the Playback Engine and precludes the use of HDX, HD Native, & Sync HD, and also adheres to the Core Audio I/O limits, I believe. If you are talking about a Digilink capable interface that has Dante incorporated (MTRX, some Focusrite units, etc.), you should still be able to use the Sync HD. I think as long as the Monitor Controller is not master, and is getting clock either from the Dante signal or via word clock, you should be good.
Scott Gatteño
Old 03-08-2018, 01:04 PM
Klosse Klosse is offline
I´m still using my Sync HD as master for the Dante network. The Sync HD is using video reference as clock source and feeds wordclock to a Rendet 3 that is then master on the Dante network.
-Klosse
Old 03-08-2018, 01:59 PM
Hi
I guess you have ditched your cards? how are you finding the latency? Much improved from cards or only a little better?
Presumably without a serial connection with sync hd Pro tools doesn't know its there?
Old 03-08-2018, 02:24 PM
uptheoctave uptheoctave is offline
A Dante network can clock off external wordclock.
The only real limitation is that Dante Virtual Soundcard cannot be clock master but if you are not using it then it isn't an issue.
Do you need the Sync HD though?
I have a Red 16 Line and an A16R, I'm using either Thunderbolt or HDX.
It is rock solid without external wordclock.
Old 03-19-2018, 11:24 AM
lancemcv's Avatar
lancemcv lancemcv is offline
I think you have to have a digilink interface like the RedNet HD32R or the older and the cheaper Rednet 5 and HD native card or Native thunderbolt to be able to sync to video ref with the Sync HD. I don't think there is a way around it. Basically you would be replacing your avid interface with a digilink rednet interface. Just using word clock you would most likely will have drift even if it's coming from the sync hd. I usually have my sync HD locked to incoming black burst or tri level sync, sync HD is the master clock.
Mac Pro 5,1 12 core 3.46ghz
OS X 12.6.1
Opencore 0.8.6
Pro Tools Ultimate 2022.10
Mac Pro 2009 upgraded to 5,1 12 core 3.46ghz
GPU RX6800XT, Samsung 970 EVO Plus pcie boot drive, Titan Ridge flashed for Mac.
Midas M32r console. iPad Pro with Avid Control
MTRX Sync Dante and Video laki Pro Tools | MTRX & MTRX Studio 10 12-05-2017 02:26 AM
Mix Rack to Dante? Matthew Steel VENUE Live Sound Systems 7 05-05-2016 05:54 AM
HD Native and Dante JCBigler Pro Tools HDX & HD Native Systems (Win) 11 12-10-2013 01:01 AM
Dante issues with PT 10 AnthonyDW macOS 3 10-08-2012 03:48 PM
Audinate Dante and PT9 njrsound macOS 1 04-25-2011 08:04 AM
