Old 10-18-2017, 11:15 AM
EddieJones's Avatar
Default Re: EUCON 3.7 crashes immediately!!!!!
Originally Posted by moranibus View Post
Thanks, Eddie, but no change at all. Eucon now even crashes by itself without even opening PT.
BTW - urgently need to mix something in the next couple of days and really don't want to do it without PT Control, S3 and Transport !!!!
The uninstall and clean EUCON can't have worked correctly. Did you run the installer from the Applications folder and then the script?
Old 10-18-2017, 11:31 AM
moranibus moranibus is offline
Absolutely. I'll give it another try.
PT Ultimate, Avid S3, Avid Artist Transport, Pro Tools Control
Old 10-18-2017, 11:43 AM
Almost, Eddie. Could even update S3 Firmware, but then crashed again while opening PT. Very bad.
Old 10-18-2017, 11:45 AM
ripekeai ripekeai is offline
Crashing here as well w/ PT12.8.2. OSX 10.12.6. Updated the control app which is incompatible with Eucon 3.6 so I'm unable to use both the iPad and Artist Mix. Glad this was only at home and not my studio but was trying to work from home today :/ How was 3.7 tested if it won't even launch?
Old 10-18-2017, 11:46 AM
jeffro's Avatar
jeffro jeffro is offline
Saw the same issue after installing 3.7 over 3.6.1. Ran the uninstaller then did a clean install of 3.7 and it's working correctly. Added a note to the Troubleshooting section of Pro Tools | Control - Support and Setup.
EddieJones's Avatar
The issue is updating from an earlier version as opposed to uninstalling. A file is not getting updated(we think). A fresh install works.
I have the whole team working on this right now so will continue to post here when I get updates.
Old 10-18-2017, 11:49 AM
PT user PT user is offline
of course my customisation has all gone now.:)...but its a small price to pay to have it running again
Old 10-18-2017, 11:53 AM
Thanks Eddie!
Old 10-18-2017, 11:58 AM
EddieJones's Avatar
They shouldn't get wiped out, they are stored here /Library/Application Support/Euphonix/UserSets/MC2User/MC_USER_SET_Root
Old 10-18-2017, 11:59 AM
Just tried it in Logic Pro 10.3.2 and I have a notice that says incompatible Eucon Version - current build = 4.03 build 134 Min Eucon 65916......
Now Im no expert but I would be hugely impressed if there were 65,916 builds!!!!
Whats more odd is that I clean installed Eucon 3.7 in accordance with Eddies instructions that work fine on Tools....but not logic int would seem...
EuControl 3.7 crashes immediately with PT moranibus Avid S1, S3, Dock and Control 11 10-19-2017 09:52 AM
Pro Tools crashes immediately Rich Crescenti 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 09-21-2010 04:44 PM
PT8 M-Powered Crashes Immediately chrisconover Pro Tools M-Powered (Mac) 10 05-31-2009 11:19 PM
LE 6.4 crashes immediately with 002R j20056 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 03-27-2005 07:37 AM
Mac G4 Crashes Immediately...I'm really new to this luapfitz Pro Tools TDM Systems (Mac) 2 09-04-2000 06:40 AM
