Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools 2020
Old 10-08-2020, 05:59 PM
The-Edge The-Edge is offline
Default Noise on Hardware Insert
So regardless of the hw insert delay Which I asked about in a separate post I’m getting a bunch of static when using the Black Audio seventeen as an insert, just adjusting any knobs input output I get noise. sorry still a newbie to analog gear and inserts in pro tools.
Thanks
Old 10-08-2020, 08:01 PM
Default Re: Noise on Hardware Insert
Thanks
Does the Seventeen make that noise when used stand alone? My guess is it does. But you need to check.
If so is the device properly grounded, are you using the proper cables? what's the pots behind those knobs? Wire wound? Carbon composition? Open/semi-open or sealed? Can you hit them with deoxit spray? Is the Seventeen new? under warranty Call your dealer if needed.
Isolate things as much as possible and test separate components. You can verify the hardware inserts work Ok with a short piece of cable...
Nobody here has your system in front of us and nobody here can magically guess what your problem is. So you have to troubleshoot it yourself.
And the final editorial question is why bother with a hardware insert? Why not process stuff in Pro Tools. I'm all for hardware and folks who have large libraries of gear, especially for tracking. But for a one off limiter.. there are untold number of limier plugins, some quite sophisticated.
Old 10-09-2020, 08:53 AM
Emi's Avatar
Emi Emi is offline
Originally Posted by Darryl Ramm View Post
And the final editorial question is why bother with a hardware insert? Why not process stuff in Pro Tools. .
Because hardware is better, you don’t have to update it and has no bugs. In the end it’s cheaper. Every time I insert hardware it spices up my mix, and if inserting hardware is not possible I prefer stock plugins (at least they do no harm).
If Michael Brauer went totally ITB doesn’t mean everyone has to do the same.
IMO
Mac Mini late 2012 i5 | Mac OS Catalina 10.15 | Motu 16A | Motu 828ES | Motu 1248 | Pro Tools 2020.11 Native
Old 10-09-2020, 12:05 PM
IMO
The hardware I lust after sure is not cheaper than software. But let it be an artistic decision and A/B the results. In this case of a limiter, presumably used sparingly or on a final output/mastering so easy to compare with a plugin.
And if the OP is fighting problems and a deadline, and can't track down the problem, then look at a plugin now. Static noise ain't going to "spice up a mix".
Simple options are (depending on use, but assuming it's mostly mastering) Pro Limiter, Maxim, Pro Compressor. or free trial iZotope Ozone.
Old 10-09-2020, 06:08 PM
See my reply to your other thread
Old 10-12-2020, 07:21 AM
K Roche's Avatar
K Roche K Roche is offline
I have two external HW units and do not get noise with either one.
I use a Bricasti M7 stereo reverb (via AES ) and a Tubecore 3U tube compressor (via analog )
Also I don't use the manual HW delay method/function, as I appears to me that the ADC function (Automatic Delay Compensation) already compensates for any delay because , it shows delay samples on the respective tracks that those units are used on as inserts ???????????????????
System :
Avid Carbon interface PTDHN 2020.11.Mid 2020 iMac 27" 3.8GHz 8-core i7 10th Gen processor,,128GB 2666MHz DDR4 memory,,2TB SSD storage,,Radeon Pro 5700 XT with 16GB of GDDR6 memory Catalina 10.15.7
"Peace cannot be kept by force. It can only be achieved by understanding" Albert Einstein
Enjoy the Journey
.... Kev...
Hardware insert mickeyrouse Pro Tools 12 7 08-29-2020 11:47 AM
Hardware insert 1&2 cutting off other hardware inserts on aux tracks Led Windows 4 12-09-2013 10:19 AM
hardware insert Downtown_BE macOS 5 12-07-2012 01:59 AM
How to insert hardware as channel insert Lqoau 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 01-19-2012 08:29 AM
Noise on insert 002R critza 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 12-07-2010 02:39 PM
