Old 03-10-2011, 07:35 AM
filobus filobus is offline
Exclamation Avid plesse read - PT 9.0.2 Disk Image corrupted
Hello Avid,
been trying to download and install the new 9.0.2 updater.
Tried 3 times and after attempting to open the disk image as usual, i got a pop up window in Firefox saying:
"Pro_Tools_902_Update image data corrupted"
Now trying Safari to see if it´s a browser problem.
Old 03-10-2011, 08:43 AM
Default Re: Avid plesse read - PT 9.0.2 Disk Image corrupted
Doesnt work with Safari either.
Old 03-10-2011, 08:53 AM
DigiTechSupt's Avatar
What kind of internet connection are you using - wired or wireless? What's your download speed like?
Wireless connections are more prone to corruption and there are a number of other factors that could contribute - router configuration, bad/loose cables, etc. I would look at those as possibly being a problem.
Are you using the download manager? If so, try using the direct link when downloading.
Avid Audio Tech Support
Support FAQ
Old 03-10-2011, 10:37 AM
Hi, thanks for replying. No My mac pro is connected via ethernet cable.Wireless is off.
But I`ve downloaded tons of upgrades from you guys and never a problem.
I tried 4 times today, 2 times with Avid download manager, 2 times with browser download. .dmg file downloads but when i opened i got always the corrupt msg.
I will try to download with my macBook pro and then copy it onto my Macpro..
Old 03-10-2011, 10:39 AM
Have you made sure to trash the previously downloaded file before redownloading? Also, you should delete your browser cache, as that may be contributing to the problem as well.
Support FAQ
Old 03-10-2011, 11:41 AM
Ok will do, thanks.
Old 03-10-2011, 11:50 AM
Avid's Avatar
Avid Avid is offline
Administrator
Also, this might help to make sure you have the complete download...
In the Mac Finder, go to the menu bar at the top, choose Finder > Preferences
Click on "Advanced", and check the first box: "Show all filename extensions"
If the download is complete, the full file name should be this:
Pro_Tools_902_Updater_70918.dmg
If you do a "Get Info" on the file, it should show this size, or very siimilar:
1.87 GB on disk (1,873,368,111 bytes)
If your download shows a smaller size, or shows the extension as ".dmg.dlm", then it is a partial download. The .dlm extension indicates that it is an incomplete download manager file. The .dlm extension goes away when the download is complete.
I tested the download on the latest non-beta versions of Firefox, Safari, and Google Chrome, and all downloaded and opened uncorrupted in my tests. So I'm fairly certain that the files are not corrupted at the hosting end.
Administrator
Old 03-11-2011, 02:55 AM
No success. Tried downloading from my macbook pro. Same result. As i said, I did dozens of downloads from Avid and other sites and never encountered this problem.
Any alternative link for downloading 9.0.2 ?
thanks
Old 03-11-2011, 08:05 AM
DonM DonM is offline
Sorry to hear your problems!
I downloaded both the Win and Mac images last evening without a problem, It was interesting that the Mac image took 8 minutes and the Windows image took 26 - even though the Win image is smaller I believe.
Load balancers do some interesting things so, I'm sure you'll get this resolved. Thanks to the support folks for responding so quickly.
Best
-D
Old 03-14-2011, 08:19 PM
AvidCS's Avatar
AvidCS AvidCS is offline
BTW... we sent the 9.0.2 Mac Updater to filobus via DigiDelivery today.
ERROR: Pro Tools 10 Installer image data corrupted.HEEEELP!!! thebandwood macOS 23 07-08-2013 11:00 PM
Pro Tools 9.02 Update Image Data Corrupted. Jwhitehead333 macOS 11 05-02-2011 03:40 AM
Disk Image Software yarrick19 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 14 02-01-2011 03:47 PM
disk image? Bermaster 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 03-29-2004 01:08 PM
Making a Image of disk! midiman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 11-18-2003 04:49 PM
