#31
Re: Popping and Crackling - the next thread ...
PC workstation: Windows 10 Pro i7 12700K RTX 2080ti 64GB DDR5 5200mhz RAM 2 Samsung 980 Pro 1TB SSDs Samsung 850 Pro 1TB SSD LG 34" Ultra-Widescreen monitor Pro Tools 12.4 A loaf of bread A stick of butter A lot of rye whiskey |
#32
#33
Now let's just hope it makes a difference... In case it helps anyone, you can pin the shortcut you create to the taskbar and delete the one from the desktop and it still works fine.
#34
Excellent. As I mentioned, you can't set Pro Tools to Run as administrator and have the shortcut command work. Best to check that the setting worked by looking in Task Manager>Details and checking the Affinity of ProTools.exe.
#35
I just wanted to follow up with a few more comments for anyone struggling with low latency performance and VIs. I installed 2020.5 and decided to redo some optimization tests.
1) Setting the processor affinity on MY system (see below) is critical. I currently use a setting of FFE for processor usage on my 6 core 8700K. 2) C-states switching and Turbo mode must be off in BIOS. I use a 4.8 GHz all core overclock with a -1 AVX offset. This is 24/7 stable with the cooling listed below. Note, I do not generally test stability with synthetic benchmarks - this is not real world testing. I set up a complex ProTools session and try to make it crash. It only takes a few tries to find the limit of your system. 3) Leave Hyperthreading On. With the Affinity switch, the extra (virtual) cores really improve performance in ProTools. 4) The way you setup your recording session can impact low latency performance. I try to avoid stacking VIs into Auxes with heavy effects. I 'think' this might allow ProTools to more easily parallelize the computations. With the above settings I can record 16 audio tracks, and 16 midi tracks with Abbey Road Drums, Kontakt Pianos, Kontakt Session Horns Pro, Kontakt Session Strings Pro, Massive, H EQ on each of 4 vocal tracks, H Delay (slap) on Vocal send; CLA Mixhub (lite) on Drum Aux, all at 24/96 for more than 3 hours continuous recording no pops, no clicks, no stops. Never a redline on CPU usage meters. All the monitoring and levels are handled in Protools. With 24/96 the 64 bit buffer gives 'unnoticeable' latency YMMV. Hope this helps someone - Yup, free advise YMMV. ejinbc Hardware Intel Core i7-8700K 3.7 GHz 6-Core Processor; Noctua NH-D15 82.5 CFM CPU Cooler; Asus PRIME Z390-A ATX LGA1151 Motherboard; Kingston HyperX Fury RGB 32 GB (4 x 8 GB) DDR4-3200 Memory; Samsung 970 Evo 1 TB M.2-2280 NVME Solid State Drive - x2 system/samples and tracking; Western Digital Red Pro 6 TB 3.5" 7200RPM Internal Hard Drive - x2 completed work and backup; Gigabyte GeForce GTX 950 2 GB OC Edition Video Card; Fractal Design Define R4 Blackout ATX Mid Tower Case; EVGA SuperNOVA G2 850 W 80+ Gold Power Supply; Motu 1248 on USB2 Software Win 10 (latest); Protools 2020.5; Kontakt Ultimate Complete; Waves Gold + CLA Mixhub; H EQ; H Delay; |
#36
And for ease of calculating a Hex number: https://bitsum.com/tools/cpu-affinity-calculator/
#37
You can'T read and interpret benchmarks like you did. You have to put the reasons into account. The SERVER class CPU is not by accident. It's a requirement. And the benchmarks are only useful if you know how to interpret them. I already did a lot of audio work with many different CPUs in the last 20 years and never a session with ONLY ONE instrument open (like here) ever hit any CPU limits. Music isn't that heavy as Video is. And we edit 4K Video here (as I sad, it's a audio/video suite) - The reason why this CPU has a low rating is because it has thread safety. Which is important if you care about file integrity. GAMING CPUs are dangerous in this manner and can cause glitches. And since the whole issue is sadly NOT reproducable in any other daw, we should look rather into same tweaks which closely refer to the Pro Tools setup. No other DAW has issues here on this machine. That being sad - IF the CPU is part of the problem - THAN it can only be an issue WITH Pro Tools which maybe do not like such CPUs. That - of course - would be another issue then.
Windows 10 Pro x64 - Intel Xeon CPU E5-2630 v4 @ 2.20GHz, 2201 Mhz, 10/20 Core(s) - 64 GB Ram - ASUS Mainboard X99-E WS/USB 3.1 (LGA 2011-v3) - Most hard drives SSD - AVID Pro Tools (Native) - AVID Media Composer Ultimate - AVID Eucon artist series - RME UFX audio interface with integrated Midi interface - ADAM Audio - HEDD audio - Brauner - Klark - Scheps - Neumann - Furmann - Sennheiser ... Last edited by dgdsu; 05-29-2020 at 08:38 AM. |
#38
Now here comes another interesting result of another test we did this morning: It seems that Pro Tools handles "disabling" of plugins different than other DAWs. Disabling the plugins on the master fader had obviously not that effect on the latency as we expected, but when we completely removed them, the latency issue has been drastically reduced. That came with a big surprise for us because we assumed that these plugins do not get into account when bypassed/disabled. "Disabling/Bypassing" (EDIT: I refer to "disabling" only here actually) them seems to be rather something like "muting" (making the effect not hearable) but usually bypassing also means that they are not in the signal flow no more. Weird ...
So it maybe makes sense to use an additional fader for listening the midi recording thru, while the master fader is muted.
Windows 10 Pro x64 - Intel Xeon CPU E5-2630 v4 @ 2.20GHz, 2201 Mhz, 10/20 Core(s) - 64 GB Ram - ASUS Mainboard X99-E WS/USB 3.1 (LGA 2011-v3) - Most hard drives SSD - AVID Pro Tools (Native) - AVID Media Composer Ultimate - AVID Eucon artist series - RME UFX audio interface with integrated Midi interface - ADAM Audio - HEDD audio - Brauner - Klark - Scheps - Neumann - Furmann - Sennheiser ... Last edited by dgdsu; 05-29-2020 at 10:26 AM. |
#39
High latency plugs on the master have been an issue. I don't think there is delay compensation on the master. Try putting an aux in front of the master - route everything to the aux and put the plugs on the aux. Then aux output to the clean no plugs master. There are a couple of videos out there re this setup and additional benefits.
PT 2024.3 DP 11.31 VEP 7.x with various VIs NI Komplete Audio 6 on HP Envy 8G i7 Quad Laptop Win11 MOTU 828es ADA8200 MTP-AV on HP Z2 G4 Xeon Workstation Win11 MOTU M4 on MacBook Air M2 2023 Sonoma.4.1 |
#40
LE 8.0.4 phantom popping, crackling. | 809578998 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 01-29-2011 08:33 PM |
Popping and Crackling with Digimax LT | Digitalkidd | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 12-13-2004 08:58 PM |
Popping and crackling | sinnagod | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 05-08-2004 07:03 PM |
Once again: popping and crackling on a AMIII | Jitter | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 12-06-2001 04:30 PM |
Need Help! Popping and Crackling Sounds!! | Chris LoA | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 10-07-2001 01:40 AM |
