Old 11-14-2008, 02:56 PM
soundboy35 soundboy35 is offline
Default Video frame/field offset when using multiple clips in PT
When adding a second video clip to the end of a previous clip a session, can you be field accurate when placing this 2nd clip, and how do you know for sure, you are retaining frame accurate sync?
MacBook Pro 15in, 2.3gHz,i7
PT 2021.x
PT12.8.x
Old 11-16-2008, 05:33 AM
Postman Postman is offline
Default Re: Video frame/field offset when using multiple clips in PT
For movies at 30fps or less you are retaining the frame accuracy of the movie files you have. Movies are placed on the timeline at frame boundaries, not field boundaries. Those boundaries are definied by the frame rate of the movie itself. There is no way in Pro Tools to move a clip by one field, change field dominance, or to even see whether a scene change happens on field one or field two. So, if your movies are created the way you want them they will remain that way in Pro Tools.
For higher frame rate movies, like 50 or 59.94fps, Pro Tools treats those as if they were 25 or 29.97fps. Pro Tools treats every 2 frames as if they were fields, and the timeline is still divided up as if it is 25 or 29.97fps (relatively speaking).
HTML code is On
One frame offset with Sony XD? philip_purcell Post - Surround - Video 0 02-20-2013 06:09 PM
video on second screen lags on frame by frame moves gonzalo.garcia macOS 4 11-14-2012 09:13 AM
PT 7.2 and Multiple Video Clips Question laki Pro Tools TDM Systems (Mac) 1 08-14-2006 01:23 AM
1 frame offset using TC reader espron Post - Surround - Video 8 02-20-2006 01:11 PM
Importing Multiple Video "Movie" clips into PT6 David Hunter Pro Tools TDM Systems (Mac) 9 07-04-2004 11:53 AM
