Go Back   Avid Pro Audio Community > Pro Tools Hardware > FireWire & USB Audio Interfaces (Mac)
Old 06-08-2015, 09:15 AM
wrongkind wrongkind is offline
Default digi002 not working in protools le7 please help me get started
i have a mini mac running pro tools 7 le and it runs great with mbox mini. but when i connect my digi002 it says "protools hardware is either not installed or being used by another program" or it just says " protools unexpectedly quit" with the ignore or restart options.. whats going on here? i tried to download the drivers on the site and they downloaded successfully . still same problem
Old 06-08-2015, 11:39 AM
Craig F Craig F is offline
Default Re: digi002 not working in protools le7 please help me get started
002 might have a bad power harness, that would cause it not to show up
Thank you,
Craig
Old 06-08-2015, 02:21 PM
i got it to show up on the protools hardware playback screen when i open up with mbox mini.. it says digi002 so i know its reading it.. it just keeps saying protools hardware not installed or being used by another program
Old 06-08-2015, 02:58 PM
Southsidemusic's Avatar
PT is not reading the hardware. That is the software driver it see so something is wrong with the 002 unit or you have a conflicting driver or the wrong driver.
Best Regards
Christopher
#thestruggleisreal
South Side Music Group
WEBHOME
Old 06-08-2015, 03:40 PM
so even though protools shows the 002 when i turn it on in the hardware screen.. the 002 could still be bad? i did the test on the 002 and all seemed fine.. and the light on the FW cable is on.. and showing in protools so i think its something causing it to crash.. im trying to figure out if its the protools le7 or the mac 10.5.8? or both? or am i missing a driver.?
Digital Input Output not working ProTools LE Digi002 theresbuzz FireWire & USB Audio Interfaces (Mac) 0 06-11-2014 02:50 AM
Need Help Getting Started With Protools S-C-3-1-3 Pro Tools M-Powered (Win) 5 05-20-2011 07:26 AM
Pro Tools stops syncing up after working for a couple of hours until PT is re-started darkwar3 Pro Tools TDM Systems (Win) 1 02-04-2003 10:16 AM
Getting Started With ProTools Smakrabit General Discussion 2 04-04-2002 01:17 PM
Ooops I goofed! Started session 16 bit in error! How to get back to working 24bit? !! Jules Tips & Tricks 5 03-24-2000 12:16 AM
