Old 02-17-2015, 07:54 AM
edwinstar's Avatar
edwinstar edwinstar is offline
Default Pro Tools 10HD&11HD not recognizing HDX connected Digidesign 192 i/o
I borrowed a digidesign 192 i/o from a friend to see if it is possible to add some extra inputs to my existing setup (mac pro 5,1, hdx, hd i/o 8x8x8, mavericks). i've read many times that hd i/o and 192 i/o can co-exist connected to a hdx card.
so far i have not gotten neither pro tools 10HD (10.3.9) nor pro tools 11HD (11.3.1) to see the 192 Interface. I tried the expansion port on the hd i/o and the second port on the card, no luck. what is interesting is that digitest sees the 192, but when i look into the hardware dialog of pro tools only the hd i/o listed.
i've also had no luck connecting the 192 to port 1 of the card, without the HD i/o
so maybe someone out there knows if i am missing something? or he has the same experience? or he/she knows a solution?
thank you all!
Old 02-17-2015, 08:43 AM
Drew Mazurek's Avatar
Default Re: Pro Tools 10HD&11HD not recognizing HDX connected Digidesign 192 i/o
I have an HD I/O 16x16 and a 96I/O connected to an HD Native PCI card and it all works on a Mac Pro 5,1.
Possible the 192 is defective?
May be trash prefs and let PT rescan?
www.drewmazurek.com
Old 02-17-2015, 08:50 AM
edwinstar's Avatar
i will try trashing the prefs, thanks!
i borrowed two interfaces, both have not been recognised so far. i don't think both are defective, since digitest recognises both...
Old 02-17-2015, 08:53 AM
Is the Digilink cable the same? Looking for commonalities.
That might be bad? Working to show up, but not connecting to the app?? A stretch for sure but.....
www.drewmazurek.com
Old 02-17-2015, 10:27 AM
DetroitT's Avatar
DetroitT DetroitT is offline
Digitest indicate a newer firmware version?
Loop sync cables connected both directions?
Old 02-17-2015, 10:41 AM
JFreak's Avatar
JFreak JFreak is offline
I've heard some horror stories about 5.1 model Mac Pro and most of the time the guy reveals that it's a 4.1 "upgraded" to 5.1
Not saying this is what you have, but for some reason -- and I don't know why -- it seems 4.1 models are more stable than 5.1 models.
Janne
Old 02-17-2015, 11:13 AM
edwinstar's Avatar
Sync Cables connected both ways.
Fimware up to date.
JFreak is a right, it is a 4.1 upgraded to 5.1, but is there real evidence, that this could be the cause for PT not recognizing the 192 i/o?
Old 02-17-2015, 12:44 PM
If you are working with multiple interfaces, I would test each one by itself. If the 192 is the digital version, you may need to configure the digital format(AES vs Optical) Does each interface appear under the hardware setup menu?
Old 02-17-2015, 01:04 PM
29CountsNY's Avatar
29CountsNY 29CountsNY is offline
I'm running a 5.1 Mac Pro that was 'updated' from 4.1 and although I am running an HD Native card my 192s, both Analog and one Analog configured as a Digital are recognized and working properly.
I know it is not HDX with HD I/O but I can confirm that the 192s are recognized on a 5.1 that used to be a 4.1 machine.
www.montabonsound.com
www.29counts.com
Pro Tools HD 2019.12 | HD Native PCIe & HD Native Thunderbolt | Lynx Aurora 16 HD | HD I/O | Digi 192 | 2010 Mac Pro 12 Core 3.46ghz | macOS Mojave 10.14.4 | 48 gigs RAM | Tascam DM3200 | Crane Song Avocet II | Antelope Isochrone OCX | Universal Audio Quad & Duo | Waves Mercury + Studio Classics v10 & Abbey Road Collection
Old 02-17-2015, 01:29 PM
edwinstar's Avatar
thanks for your inputs!
that's the problem: the 192 is not listed in the hardware setup dialog (both in 10&11), but it shows up in digitest.
i will hook up the 192 by itself tomorrow.
so basically you all are saying that theoretically it is possible to run a 192 i/o connected via HDX card with the most recent version of pro tools 11HD on a mac with mavericks installed. that gives me hope!
Upgrade from PT 10HD to PT 11HD? (bought 10HD on eBay) Concept Chelia Pro Tools 10 7 09-12-2014 04:01 AM
PT 11HD still shipping with PT 10HD? jrmintz macOS 10 03-09-2014 12:12 PM
96K session in 10HD with UAD2plugs, will not run on 11HD ericgreedy Pro Tools 11 4 12-19-2013 07:42 AM
Can't import FCP OMF in 11HD, but can in 10HD Arno Peeters Pro Tools 11 1 10-30-2013 06:24 AM
Upgrading from 9HD to 10HD/11HD simonyeah Pro Tools 11 6 09-30-2013 02:10 PM
