Just got Windows 7- have mbox 2 pro. what do i do??
Just bought a new pc with windows 7 already installed..
My install disc, is not wanting to work with 7. I cant even get drivers to install for the mbox 2 pro.. Can anyone help??? thanks |
Re: Just got Windows 7- have mbox 2 pro. what do i do??
Windows 7 is not supported yet.
James Shelby SRS Labs Aurora, Colorado |
Help Us Help You ______________________________________ Chris Pro Tools 2024.3 Focusrite LS56 Focusrite Pro40 (2) TC Electronic Studio Konnekt 48 Avid Artist Mix/Control Slate Digital VRS8 Analogue Tonebuss 24 Channel UAD-2 OCTO Core Accelerator UAD Volt 2 macOS 10.15.7 32 GB DDR4 RAM 4.01GHz Quad-Core Intel Core I7 NVIDIA GeForce GT 740 2 GB |
So, reinstall win7 in the 32 bit version. Although Digidesign does not guarantee it to work, it does work just fine. If I were you, I'd make a dual boot system like this: Use Acronis Disk Director to resize the current operating system partition to one third the size. Make a second partion in the middle third of the hard disk. Format this new partition to NTFS. Use a Win 7 disk to install the 32 bit version to that new ntfs partition. (The reason you install in a formatted partion rather than an unpartitioned section, is to prevent a an extra system partition from being created) Set up a boot selector to dual boot. (You'll have to figure thus out) The last third of the drive is slower, which is why I did not recommend using the last third of the drive.
MBox 2 Pro connected to motherboard 4 pin firewire port Dell Inspiron 9300 laptop 2.0 gHz Pentium M 2 gB ram Lacie Rugged 5400 rpm firewire 800 on Siig Cardbus adapter Roland 700SX stage piano Studio Projects C3 mics Melodyne Plugin Dual Boot: PTLE 8.0.1 on Windows 7 Enterprise 32 bit PTLE 8.0.1 on XP Media Center SP3 |
Is that correct Mr Thread Starter, you have a 64 bit system?
These are the kinds of topics that sometimes muddies the already muddy water. When you say, it doesn't want to work, what does that mean exactly? Is there an error message, and if so, what does it say? Or does it start installing and hang halfway through? |
You original questions is:
Just got Windows 7- have mbox 2 pro. what do i do?? The answer is wait until Digidesign writes and tests a version of Protools that is written to work with Windows 7. In the mean time continue to use your old system for Protools. I'm not trying to be a smart *****. It is the reality of the situation.
Obsidian Dragon
MacbookPro14,3 - Intel Core i7 3.1 GHz, 16 GB MacOS 13.6.6 running Protools 2024.3.1 Mac Studio M1Max - 64GB MacOS 14.4.1 running Protools 2024.3.1 |
okay i shall try to do the dual boot thing.. it didnt come with a windows 7 disc, so i suppose ill throw on the old windows xp as the 2nd OS..
Thanks all for your help -stribs |
You might have to use Grub as the boot selector. It's free from Linux sites. Windows7 does not use boot.ini and i could not figure out how to add an xp operating system to the Win7's bootloader. So I am using Grub as the boot selector. It was easier for me to figure out.
FWIW it has been my experience to install the XP system first then W7 in a dual-boot scenario. i always had trouble with managin' the bootloader with W7 installed first. and currently i have a 6 OS boot drive. but might be user error but that's been my experience
bassist...deep pocketz anyone???!!! The Basschakra Lucid Soul Trip i7 Builds - Specs and Results HDNative | Omni | i7-3930K OC'd 4.0GHZ | ASUS X79 Sabertooth | 32GB GSkill DDR3 2133 ram | mo' stuff |
Updating Pro Tools and Mbox from Windows XP to Windows 7 | ryanjantz | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 05-29-2011 04:22 PM |
Windows 7 and the MBox 2 Pro | bms9nmh | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 11-23-2010 04:09 PM |
Original MBox with Windows Vista or Windows 7 | JoshuaD | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 12-16-2009 06:57 AM |
Original MBox on Windows Vista or Windows 7 | JoshuaD | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 12-16-2009 06:50 AM |
MBox Windows XP - when ?????????? | brownmusic | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 9 | 09-11-2002 12:27 AM |
