Old 02-14-2003, 11:20 AM
ThinDave ThinDave is offline
Default DAE Error -9035
Hey all, I haven't used my 001 in a while but just installed 6.0 today while getting back into things. Whenever I try to load a demo session or an old one, I get the following error after it runs through the audio files:
Could not complete the "Open Session..." command because: DAE error -9035 was encountered.
Also, Apple System Profiler shows that there is a card installed in the slot, but cannot identify it. Can someone check to see if the card is identified under Mac OS X?
One last bit of info - the Midi interface shows up in the Audio MIDI Setup app...
Any ideas? A DUC search turned up nothing...
Thanks, Dave
Old 02-14-2003, 11:34 AM
Default Re: DAE Error -9035
Hmmm, well, I copied the session to my main drive and it works now - could it have been fragmentation? I'll back that drive up and reformat it to check....
Old 02-14-2003, 01:56 PM
Ok, i spoke with Digi Tech Support and it looks like the problem had to do with the driver or the format of the disk (which was HFS+). I moved my stuff off, erased the disk and re-loaded my sessions - it's all good now!
Thanks Digi!!!
G5, with Dae error -9035 Please Help Awesome 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 03-31-2005 02:00 PM
DAE Error -9035 Help! Musepro 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 07-22-2004 10:36 AM
DAE error-9035 Dr Fletch Pro Tools TDM Systems (Mac) 1 06-30-2004 11:33 AM
DAE error -9035????? peneslapepe 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 06-28-2004 04:34 PM
DAE Error 9035 Jeff Schmidt Pro Tools TDM Systems (Mac) 2 09-03-2003 10:56 AM
