Old 01-24-2024, 05:49 AM
raisound raisound is offline
Default iZotope RX Connect clip by clip unabled
After updating to 2023.12, a clip by clip and multi-input/mono mode options became unabled in RX Connect AudioSuite plugin
In every other plugins they work as before
Did anybody else faced this problem?
Old 01-24-2024, 03:53 PM
audiolex1 audiolex1 is offline
Default Re: iZotope RX Connect clip by clip unabled
It won't work in multi input mode. Mono mode it will work.
Are you saying that in both cases it doesn't work? I can't see what you have selected for input mode.
Mac Pro 5,1. 3.46 12 core, 128 gigs ram, 580 GPU flashed Apple EMI, 3 monitors
PT Ult 2023.6, OSX 10.14.6, 3 card PCI-e expansion with 3.2 USB Sonnet card.
OCTO 8 card, Apollo 8 Quad, UAD quad satellite FW.
Almost every plugin
Old 01-25-2024, 01:37 AM
It doesn't even have multi-input or mono modes option as it did before
And I cant choose clip by clip mode, and that is much more important
All other plugins work as they did before
Old 01-25-2024, 11:31 AM
That is strange. I'm using RX9 Connect now with 2023.6 and I have those options.
Did this just happen with 2023.12?
Can you go back to an earlier version? You can have multiple versions installed. Just rename the app to reflect the PT version.
Almost every plugin
Old 01-26-2024, 12:31 AM
Yeah, right after updating to 2023.12
Didn't know about having multiple versions installed, I'll try it, thanks!
Old 01-29-2024, 11:33 AM
bauerjan bauerjan is offline
The iZotope RX 10.5 update solves everything.
Version 10.5.0 released January 23, 2024
CHANGED minimum supported macOS version to macOS Monterey
ADDED support for macOS Sonoma (10.4.2 was also tested for compatibility on macOS Sonoma)
ADDED support for Cubase 13 and Reaper 7
FIXED RX app changes audio driver to 44.1kHz sample rate upon opening the app manually or with RX Connect
FIXED RX 10 Connect Audiosuite clip processing modes are inaccessible on Windows in Pro Tools 2023.12
FIXED regions of silence are rendered by some iZotope plugins when hosted in the RX 10 application
FIXED crash when Japanese is selected as the tooltip display language in the app
FIXED low contrast of spectrum axis labels and gridlines in the RX application
FIXED low contrast of module grabber UI element in Module Chain
Old 01-30-2024, 08:35 AM
domilik domilik is offline
This is working with the newest version, BUT:
Now I cannot set a handle length in plugin windows of RX Connect, AmbienceMatch and DeHum. Handle and "whole file" is greyed out.
Anybody else with this problem?
PT Ultimate 2023.12
Win10 Pro 64bit, 64GBRAM
MacStudioMax, 64GBRAM, 32GPU, Monterey
MTRX Studio, HDnative, RME UFX, Yamaha 01v96i, S3, S1, PT Dock, Nuendo 12
HTML code is On
Randomly can't select single audio clip on timeline - Clip then disappears (2022.9) take77 Pro Tools 5 10-14-2022 06:15 PM
Selecting a clip in Edit window fails to select clip in Clip List oldskool Pro Tools 2020 8 09-28-2021 01:43 AM
Nudging a clip past another clip removes the stationary clip evil.beasts Pro Tools TDM Systems (Mac) 0 11-01-2017 11:08 AM
x form rendering blank files when choosing clip by clip audiosuite dj_grimmace AAX Plug-ins 2 06-21-2017 11:29 AM
x form rendering blank files when choosing clip by clip audiosuite dj_grimmace Pro Tools 11 1 03-04-2017 12:35 PM
