Old 02-24-2023, 12:45 AM
ginziro ginziro is offline
Default ProTools12のミックスウィンドウをフィジカルコントローラで操作する方法
ProTools12のミックスウィンドウを、フィジカルコントローラ(ROLAND A-500PRO。Mackie control準拠のMIDIコントローラ)で操作するための方法を教えて下さい。
Old 02-24-2023, 06:45 AM
Ben Jenssen's Avatar
Default Re: ProTools12のミックスウィンドウをフィジカルコントローラで操作する方法
Translates to:
Please let me know how to operate the mix window of , with a physical controller (ROLAND A-500PRO, MIDI controller conforming to Mackie control).
If you are thinking of using the small faders on the Roland keyboard, I don't think there is any way to do that.
I don't think it's possible to control PT with Mackie protocol.
(Added: Oh, you mean, of course Mackie 'HUI' protocol. Yes PT12 can use HUI, but it's very old, from the nineties, and somewhat limited. I don't have any details, perhaps someone else can enlighten us.)
Old 02-24-2023, 05:42 PM
protools12のミックスウィンドウを、フィジカルコントローラ(roland a-500pro。mackie control準拠のmidiコントローラ)で操作するための方法を教えて下さい。
ご教示ありがとうございます。
ptの設定→ペリフェラルでhuiを選択しても「コミュニケートできません」と出ます。
残念ながらa-500proでコントロールする方法はないということだと思いますが、例えば、何かでhuiに互換するよう な方法はあるものなのでしょうか?
Old 02-24-2023, 05:47 PM
ご教示ありがとうございます。
Translates to
Thank you for your instruction.
Even if hui is selected in pt settings → peripherals, "cannot communicate" appears.
Unfortunately, I don't think there is a way to control it with the a-500pro, but for example, is there a way to make it compatible with hui?
Sorry. Can't help you with that.
Old 02-25-2023, 12:50 AM
Originally Posted by ben jenssen View Post
translates to
sorry. Can't help you with that.
わかりました。ありがとうございました。
Old 02-26-2023, 06:12 PM
Top Jimmy's Avatar
I checked the user manual for the A-500PRO and could not find any mention of a HUI mode. The HUI protocol requires bidirectional communication which is something not needed by standard MIDI devices. HUI continuously uses pings and replies to keep the connection alive. If the A-500PRO doesn't have a HUI mode, then it won't work as a HUI controller within Pro Tools.
HUI communication messages are much more than just SYSEX or CC data, so they cannot be recreated by trying to send standard SYSEX or CC values.
You can still use the A-500PRO to play virtual instruments within Pro Tools. You don't need to have a MIDI keyboard configured in the peripherals settings to use it.
James Cadwallader
Old 02-26-2023, 06:18 PM
JFreak's Avatar
JFreak JFreak is online now
ここで英語を話せますか? 別の日本語サブフォーラムがあります
https://duc.avid.com/forumdisplay.php?f=78
Janne
Old 02-26-2023, 10:36 PM
Originally Posted by top jimmy View Post
i checked the user manual for the a-500pro and could not find any mention of a hui mode. The hui protocol requires bidirectional communication which is something not needed by standard midi devices. Hui continuously uses pings and replies to keep the connection alive. If the a-500pro doesn't have a hui mode, then it won't work as a hui controller within pro tools.
Hui communication messages are much more than just sysex or cc data, so they cannot be recreated by trying to send standard sysex or cc values.
You can still use the a-500pro to play virtual instruments within pro tools. You don't need to have a midi keyboard configured in the peripherals settings to use it.
ご教示ありがとうございます。
a-500のメーカー(roland)に本件を問い合わせたところ、huiだと可能性あるとのことで設定を試し ていましたが、ダメのようですね、
言う通り仮想楽器の演奏はできるので、それで使用しています。
ありがとうございました。
Old 02-26-2023, 10:59 PM
すみません。
残念ながら英語は話すことができません。
Pro Tools 12.5でプロジェクト作成時にエラーが出る Avid Audio Japan Admin Pro Tools HD, HD Native、ICONフォーラム 0 06-16-2016 04:02 AM
Pro Tools 12.5でプロジェクト作成時にエラーが出る Avid Audio Japan Admin Pro Tools (Non-HD, LE, M-Powered, Express) フォーラム 0 06-16-2016 04:02 AM
Avid オーディオ (Digidesign)製ハードウェアの再登録(名義変更)の方法 Avid Audio Japan Admin Pro Tools HD, HD Native、ICONフォーラム 0 05-20-2016 07:33 AM
Pro Tools のインストール/アンインストール方法 Avid Audio Japan Admin Pro Tools (Non-HD, LE, M-Powered, Express) フォーラム 0 05-18-2016 03:46 AM
Avid オーディオ (Digidesign)製ハードウェアの再登録(名義変更)の方法 Avid Audio Japan Admin Pro Tools (Non-HD, LE, M-Powered, Express) フォーラム 0 05-18-2016 03:10 AM
