  #21
Old 08-13-2022, 11:23 AM
glasswing glasswing is offline
Default Re: First experience with NVMe M.2 in enclosure - bad.
The sleep problem is not a big PITB - to sleep, I turn off the new wiz bang Apple keyboard and put the machine to sleep. It wakes up in around ten minutes and then I sleep it again - and that usually sticks
Mac Studio Ultra / 128 RAM/2TB HD / Avid HDX Chassis / 2 X Sonnet Echo Dual NVMe Thunderbolt Docks w Samsung 970 EVO Plus (6TB) / Avid C24 / Avid 16X16 I/O Analog / Lynx Aurora 16/16 1/O Analog / Dangerous 2 Bus / Benchmark ADC1
www.glasswing.com
www.richardsales.com
  #22
Old 08-13-2022, 11:34 AM
Originally Posted by Ben Jenssen View Post
Thank you, Darryl.
I have a
OWC Envoy Express
on order.
I'll just see how that works out.
IN reply - first I bow to Darryl's greater knowledge on all these fronts. I knew about the speed limits going in with the Echo Dual but figured it was faster than my previous SSDs and should work fine - which it does.
I use one for Pro Tools sessions - split between two NVMes as JBOD and the other is Raid 0 for virtual instruments. Both work well.
Our sessions here aren't huge - although we've had a few 100+ track sessions.
The ONLY weirdness I have is some plugins. And no weirdness compares with the crippling time lost and reboots with the cheese grater.
The fan noise only seems to show up when I'm shutting down. We record a lot of vocals in the room here just a few feet from the Mac Studio and Echo Duals. All together they are way quieter than the old 2012 cheese graters and spinning drives. Michael Brauer mixes most of our music and loves the sound etc. I would say in the real world it's all extremely quiet and works great.
Sometimes the Echo Duals will light up when the system is sleeping.
I'll contact Sonnet about that sometime - but they don't feel hot and everything seems to be working so I'm happy.
You have to take everything I say with the grain of salt that my last machine (actually two including Vienna Ensemble Pro '08 Mac Pro server) had stage 5 brain collapse. I swoon with happiness with my current setup.
www.glasswing.com
  #23
Old 08-14-2022, 06:53 AM
smurfyou smurfyou is offline
Thanks for the report!
~Will
  #24
Old 08-14-2022, 10:24 AM
nsureit nsureit is offline
I got the Sabrent Rocket XTRM-Q 2TB USB 3.2 / Thunderbolt 3 External SSD last year. I connected it to my Dell dock via TB3 port (Dell Win10 laptop, PT Ultimate/MTRX Studio/HDXx1). I store all my sessions there. No issues whatsoever (knock on wood). Transfer rate is superb. The Sabrent enclosure does get warm from time-to-time.
  #25
Old 08-14-2022, 01:12 PM
Righty27 Righty27 is offline
Thanks Richard - FYI, I’ve been corresponding with Sonnet support over recent days as I typically leave my Mac ‘on’ and constant disconnects when it sleeps would be impractical, especially for quite an expensive setup (more so in my part of the world where the dock alone is close to $500).
They have confirmed that one should expect 1,500MB/S from each drive and my understanding is that the disconnect dialog messages on wake, which only affect Macs, can be ignored. The drive(s) apparently do disconnect (after flushing the cache) in order to save power during sleep, however should then reliably re-mount when the Mac awakes, with no risk of data loss.
This doesn’t quite match with your experience, so I wonder if anything else in the Thunderbolt chain might be affecting trying to get your Mac to sleep, or why your Sonnet dock appears to wake randomly when the wider system is ‘asleep’.
FWIW, I’ve also been ‘researching’ NVMe drives and Sonnet support confirmed that the Samsung 980 Pro and WD_Black SN850 that I’m considering are fully compatible. However, when looking at other Thunderbolt enclosures, I have come across some apparent issues with the 970 Evo Plus that you’re using.
Sonnet publish a compatibility chart - https://www.sonnettech.com/support/d...patibility.pdf … which suggests that 970 Evo Plus drives that shipped prior to 2020 require a firmware update to be compatible with MacOS … just in case this information is useful for when you contact Sonnet :)
  #26
Old 08-14-2022, 02:19 PM
basslik's Avatar
basslik basslik is online now
Having success with (2) Samsung 970's in my Syba card.
MAC PRO 2010 5,1 3.46hex 128ram - MONTEREY 12.7.4- PT 2024.3 / 003 RACK SIGNATURE MOD / DIGIMAX FS / PCM90 2CHANNEL SPDIF
  #27
Old 08-14-2022, 08:25 PM
Ben Jenssen's Avatar
That would be a PCIe card with slots for 2,5" SSDs, I think. The main topic in this thread is NVMe cards in external Thunderbolt 3 encosure, with much higher transfer speeds than that. Sorry, I should have been clearer on the Thunderbolt 3 part in the title.
  #28
Old 08-14-2022, 08:46 PM
I think he is talking about the Samsung 970 Evo (maybe Evo Plus) M.2 drives on a Syba card... one of the switch based cards I've been recommending.
  #29
Old 08-14-2022, 08:48 PM
Originally Posted by Darryl Ramm View Post
Nope Samsung 970 (maybe Evo) M.2 drives on a Syba card... one of the switch based cards I've been recommending.
Ah, I see. Sorry.
  #30
Old 08-15-2022, 07:41 AM
I suspect the culprit might be on the USB2 chain. Apparently Monterey is not a big fan of USB 2 and can cause troubles. Occasionally thumb drive authorization keys drop out and I have to reseat them. And I currently have 24TB of backup on the system - which is foolish but I haven't had time to set up my backup server in the back room. I've been in the middle of a project that will pause on the 19th - and hopefully I can dig a little deeper then - update from PT 2021.12 and see what comes.
Andy at Sonnet recommended the 970 Evo Plus. I suspect they're working fine. I'm not sure when they shipped! That could be another zit I'll research after the 19th - depending on the outcome of other hopeful fixes.
Why do you leave your stuff on all the time? I used to do that but power outages here (an island off the left coast of Canada) and electric bills encouraged me to sleep or shut down.
THanks!!!
www.glasswing.com
NVMe upgrade for Mac Pro 4.1/5.1 Mojave mcnichols Pro Tools 2019 239 11-04-2023 09:41 AM
External SSD/NVMe recommendations? reichman Post - Surround - Video 17 05-10-2022 09:17 AM
Mac Pro 5,1 Cost effective NVMe SSD drives Howardk Pro Tools HDX & HD Native Systems (Mac) 12 12-23-2020 11:18 PM
New 8th Gen i7 with NVMe m.2 SSD spock999 Pro Tools 2018 26 02-22-2018 11:47 PM
Intel SSD NVME/PCIe Porn Darryl Ramm General Discussion 0 04-03-2015 02:02 PM
