Old 11-12-2020, 08:54 AM
domilik domilik is offline
Default Edit Window follows S3?
Hi everybody,
I just do not get how to make the edit window follow my track oder bank selection on S3?
There is this PT pref "Edit Window follows Bank Selection" which worked fine with former HUI-Controllers or ICONs, but how do I setup this with the S3?
And is there somewhere a user manual whith a proper explanation of all the settings in the EuControl software? Especially the "General"-Tab has so many settings which are not really self-explaining.
Thanks a lot!
Domilik
PT Ultimate 2023.12
Win10 Pro 64bit, 64GBRAM
MacStudioMax, 64GBRAM, 32GPU, Monterey
MTRX Studio, HDnative, RME UFX, Yamaha 01v96i, S3, S1, PT Dock, Nuendo 12
Old 11-12-2020, 11:06 AM
Ryan Young's Avatar
Ryan Young Ryan Young is offline
Default Re: Edit Window follows S3?
Originally Posted by domilik View Post
Hi everybody,
Thanks a lot!
Domilik
I'm not at my computer right now, but isn't there a similarly named option within EuControl?
-Ryan Young
•2019 Mac Pro 3.5 GHz 8-Core Intel Xeon W - 48 GB 2666 MHz DDR4 (OS 10.15.5) •HD Native PCIe, HD Omni, 192 I/o, Pro Tools Ultimate •Avid S3 + Dock •Blackmagic Intensity Pro (HDMI) •5.1 Room with JBL LSR4300 series
Additional Systems
•2010 Mac Pro 2 x 2.66 GHz 6-Core Intel Xeon - 48 GB 1333 MHz DDR3 (OS 10.14.6) •HD Native PCIe, 192 I/o, 96 I/o, Pro Tools Ultimate •McMix (x4), McControl (x1), JLCooper Surround panner for D-Command ES, Avid Control •Blackmagic Intensity Pro (HDMI) •7.1.4 Room with JBL LSR4300 series
•2017 MacBook Pro 2.8 GHz i7 - 16 GB 2133 MHz LPDDR3 (OS 10.14.6) •HD Native TB, HD Omni, Pro Tools Ultimate •McMix (x1), McControl (x1), Avid Control * or * D-Command ES Main Unit •Fed into whichever system is the main system
Old 11-12-2020, 01:27 PM
Halfmoon Halfmoon is offline
For a manual, download the latest Using EuControl Surfaces.pdf from here:
https://avid.secure.force.com/pkb/ar...Product-Guides
M
Old 11-12-2020, 09:35 PM
JR Fountain JR Fountain is offline
That pref is all I have selected and mine works fine. The only thing to look for in EuControl is under the Assign tab. Ensure all your faders are set to "auto assigned".
Hope that helps.
J.R.
J.R. Fountain
credits: www.imdb.com/name/nm0288354/
system: Mac Studio Ultra, 128 GB RAM, macOS 13.6.1, MTRX Studio, S3 / Dock, PT Ultimate 2023.12
Old 11-13-2020, 08:35 AM
Thanks a lot for your answers, I'm not sure, if I made myself clear, I'm looking for the option, that when I bank or select tracks on my controller, the edit-window in PT should follow my view. Not vice versa.
I do not find a setting like that in EuControl Software, or am I wrong? It's just the option in PT prefs, but that does not work (here). You're sure that one works at your place?
Thanks again!
(PS: I DO find a setting in PT-Control-app (on iPad) that the DAW view follows the tracks-view on the app, but I want to do my selections on the S3...)
PT Ultimate 2023.12
Old 11-13-2020, 11:50 AM
This is working for me.
Pro Tools prefs under Mixing->Controllers "Edit Window Follows Bank Selection" & "Mix Window Follows Bank Selection"
PT Ult 2020.5
HD Native TB + Omni
MacbookPro 2019 i9
macOS 10.14.6
Scott Gatteño
Mix Window Freezes but Edit Window works fine. wwicklund 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 07-10-2022 10:57 AM
MIDI edit issue in Main Edit Window SomeOtherGuy Pro Tools 2020 4 04-02-2020 12:03 AM
Link track selection from edit window to mix window? jaminjamesp Pro Tools 12 7 01-16-2017 05:37 PM
Midi edit window stuck to edit window lvsranch Pro Tools 11 7 04-04-2015 12:42 PM
Cannot change EDIT MODE in edit window Xavior Pro Tools M-Powered (Mac) 2 05-24-2007 12:51 AM
