Old 02-04-2019, 04:38 PM
ritaM ritaM is offline
Default MIDI only recording at velocity 64 suddenly
Hi, I am recording MIDI, the same exact way that I always do*—*I have not changed a thing*—*and yet, all of a sudden, it's recording all my notes at velocity 64, no matter what I do. I'm going to keep experimenting here, but if anyone knows a possible solution I would be so grateful! Thank you.
Macbook Pro 10.5.8, 2.16 Ghz Intel Core Duo, 2 GB RAM, Protools LE 8.0cs3, Mbox2 Pro, Ivory 1.71 RTAS, Melodyne Plugin 1.0.2
Old 02-04-2019, 04:54 PM
Sardi Sardi is offline
Default Re: MIDI only recording at velocity 64 suddenly
Do you have MIDI real-time properties enabled with a fixed velocity in there?
Have you tried another instrument? Some instruments can have velocity restrictions built in to the actual plugin.
I know you said you haven’t changed anything, but this sort of stuff doesn’t usually happen on it’s own.
Flatline recording, velocity meters and mbox not recognizing audio input? sak1016 Windows 3 07-06-2015 09:52 AM
MIDI Volume or Velocity Change results in part muted MIDI sound gavriil1 Pro Tools 10 2 07-01-2013 10:23 AM
Can't edit velocity only anymore? Notes copying with velocity data... kingtinker Pro Tools 10 5 11-12-2011 10:53 AM
PT8, Sustain pedal, velocity problems while recording ChrisSimon MIDI 1 08-20-2009 05:23 PM
midi velocity Jepse MIDI 0 12-30-2004 07:24 PM
